brake line leaking - how to fix ?
04-28-2014, 08:49 PM
Bug brake line leaking - how to fix ?
Hi guys,
My right frontal brake caliper is leaking oil right at the connection (where the brake line connects to the caliper with a bolt)
The guy at the MOT station said that it was a leaking gasket. my parts dealer said it was a claw thingy i need to fit.
You guys got any ideas ?
Build your dreams.
Ford Puma 1.7 Zetec-s Daily
Toyota AE86 Levin Coupe "Jinxy"- Dreamcar
Mitsubishi sapporo - bosuzoku project
04-28-2014, 09:29 PM
do it up tighter, it seals on a taper not on a gasket/ seal.
You should really undo the other side with the swivel end, otherwise you twist the brakeline...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-28-2014, 09:47 PM
So i just need to tighten it more ? allright Big Grin
Build your dreams.
  fuel line hose from the pump Wikizz 4 6,287 10-16-2017 07:11 PM
Last Post: jdm86gtz
  Anyone know how to fix the digital clock? kawo 0 3,493 05-02-2014 08:54 AM
Last Post: kawo
  Dome light fix Jezza_hr 2 5,773 05-01-2014 10:14 PM
Last Post: Jezza_hr
  How to fix a floating idle on a Toyota 4A-GE motor Homem Bomba 8 24,540 08-27-2013 12:55 AM
Last Post: jondee86
  brake caliper/line fitting Eifelaner 9 12,851 04-15-2013 11:38 AM
Last Post: Eifelaner
