brake line leaking - how to fix ?
04-28-2014, 08:49 PM
Hi guys,
My right frontal brake caliper is leaking oil right at the connection (where the brake line connects to the caliper with a bolt) The guy at the MOT station said that it was a leaking gasket. my parts dealer said it was a claw thingy i need to fit. You guys got any ideas ? Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
04-28-2014, 09:29 PM
do it up tighter, it seals on a taper not on a gasket/ seal.
You should really undo the other side with the swivel end, otherwise you twist the brakeline... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-28-2014, 09:47 PM
So i just need to tighten it more ? allright
fuel line hose from the pump | Wikizz | 4 | 5,942 |
Anyone know how to fix the digital clock? | kawo | 0 | 3,329 |
05-02-2014 08:54 AM Last Post: kawo |
Dome light fix | Jezza_hr | 2 | 5,437 |
05-01-2014 10:14 PM Last Post: Jezza_hr |
How to fix a floating idle on a Toyota 4A-GE motor | Homem Bomba | 8 | 23,203 |
08-27-2013 12:55 AM Last Post: jondee86 |
brake caliper/line fitting | Eifelaner | 9 | 12,085 |
04-15-2013 11:38 AM Last Post: Eifelaner |
