Levin Coupe from Croatia - NOW SR86 with IRS
01-17-2005, 01:23 AM
Post: #101
You should put the gauge somewhere where the oil is the hottest. Not the temp after a cooler.
01-17-2005, 01:25 AM
Post: #102
He refered to the pressure sender I think...and he also mentioned to put it in the line TO the cooler...still not ideal, but better than after the cooler.
01-17-2005, 02:32 AM
Post: #103
I was refering to the oil temp. gauge. Smile Im mounting it as close to the engineblock as possible before the oilcooler.. I know that the best place to mount it is in the oil pan, but i hope that this works just as good. Afterall the outtake to the oilcooler, should be the place where the oil is the hottest.
01-17-2005, 11:03 AM
Post: #104
Ian.G Wrote:how much trimming was required after you'd removed the spinning air vents ? I guess they are 52mm gauges yes ?
I spent an hour triming the dashboard with dremel tool.
Oil temp sender will have to go to the oil pan.
Still no idea where to put oil preasure sender because it's bit big and bulky.
01-21-2005, 06:49 PM
Post: #105
T peice
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
Left: OEM presure sender
Right: VDO presure sender
01-21-2005, 06:56 PM
Post: #106
So I see you're following my suggestion...should work just fine since I didnt think it up myself Tongue
01-25-2005, 01:24 PM
Post: #107
ZaX new rice parts.
01-25-2005, 04:25 PM
Post: #108
My valve covers and sump remind me of this.... Evil
01-25-2005, 04:30 PM
Post: #109
One pic for my friend mux.
01-25-2005, 04:37 PM
Post: #110
Zaxyour going so well great project where you get oil pan is it new?
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,647 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,794 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 726,187 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 39,457 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,355 08-13-2015 03:22 PM
Last Post: DidiDex
