Levin Coupe from Croatia - NOW SR86 with IRS
04-21-2010, 11:42 AM
Post: #621
Looking great Zax!! Glad to see her back, what a transformation!
05-03-2010, 10:41 AM
Post: #622
http://www.youtube.com/watch?v=u8lxEFiBezQ
Is alive. First test drive on a small poligon. I love the power delivery and how rear end squats under the acceleration. We fixed some bugs (fan pushing air out, one boost leak...) Some pics Ekipa se skuplja I prva vožnja nakon 18 mjeseci šarafljenja, lijepo je to kad dođeš do cilja iako stara kineska kaže da je bitno putovanje a ne cilj. Drifting - best fun you can have in your car with your pants on! |
05-03-2010, 10:48 AM
Post: #623
Awesome.
05-03-2010, 06:42 PM
Post: #624
nice build!! i love it!
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
05-03-2010, 08:00 PM
Post: #625
Awesome ZaX, sounds great and it drift!!!!
05-03-2010, 11:58 PM
Post: #626
Congratulation it look and sound awesome
SR Team BURN THE RUBER NOT YOUR SOUL! |
05-12-2010, 04:07 PM
Post: #627
Latest specs Toyota Corolla AE86 Engine Engine SR20DET 2.0 liter DOHC Turbocharged - Stage 3 Horsepower 319 hp @ 5700 rpm Torque 420 Nm @ 4500 rpm Boost 1.2 bar ECU - Nissan + Nistune Nismo 555ccm fuel injectors Walbro 255 fuel pump Garrett GT2860RS .64 aka. Disco potato Autobahn manifold Blow off Valve Type-china Front Mount Inter Cooler Kit Lastovčić Extreme Power 70mm exhaust Manual boost controler - 3barr racing A'pexi Power Intake Air Filter 300ZX Z32 air flow sensor Z32 fuel filter Spec stage 3 clutch kit electric fan custom engine mounts Interieur Heigo 6 point roll cage flocked dashboard Modified hidro handbrake TIM boost gauge VDO oil pressure gauge VDO oil temp gauge Sparco Evo bucket seat Sparco harnesses Sparco steering wheel Suspension Driftworks CS2 coilovers 8/6 kgf/mm Driftworks Lower Arm Front and Rear Custom tension rod Custom Tie rod + tie rod end custom designed steering knuckles KAAZ S14 2-way metal LSD 3.916 final gear S14 rear swaybar AE86 front swaybar alloy subframe locking kit S13 front brakes S13 rear disc + drum brakes Conversion from 5 bolt to 4 x 114,4 Sportmax XXR 15x8 ET0 wheels Borbet Type A 16 x 7,5 wheels x 4 Borbet Type A 16 x 9 wheels x 2 Kerscher Carmona 16 x 9 wheels x 4 Puno raznih 15 i 16" felgi Exterieur Zenki front bumper with lip spoiler Kouki side step CBY overfenders Custom made hood vent Huge APR Carbon 3D wing Gear ratios with 7200rpm redline and 205/50-R16 tires 1st gear 60 kmph 2nd gear 105 kmph 3rd gear 152 kmph 4th gear 199 kmph 5th gear 238 kmph Final drive ratio 3,916 Drifting - best fun you can have in your car with your pants on! |
05-12-2010, 04:52 PM
Post: #628
Why the rear wing for drifting Zax?
If its too much just throw it in the mail towards Holland A wheel to steer the front of the car A pedal to steer the rear |
05-12-2010, 05:30 PM
Post: #629
well thats some proper gt wing there!
05-12-2010, 11:11 PM
Post: #630
Lajoosh Wrote:well thats some proper gt wing there! Carbon. Needs some proper body kit. Car went on dyno today to check the fueling. SR20DET, 1bar of boost, GT2860RS and other stage 3 supporting mods. Started with this Finished with this Full boost at around 3000rpm, holds till red line. 301 wheel HP at 6300 rpm, 95RON. Does this numbers justify the wing? Drifting - best fun you can have in your car with your pants on! |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 15,104 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 161,293 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 740,292 |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 40,300 |
04-07-2016 12:15 PM Last Post: mad.matt |
DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 5,465 |
08-13-2015 03:22 PM Last Post: DidiDex |
User(s) browsing this thread: 16 Guest(s)
