Lift Supports Rear 85 Corolla 3 door liftback AE86
07-25-2007, 06:38 AM
Greetings: I have been working with an individual to find a good set of reasonably priced lift supports for the above model.. Can anyone tell me if the supports for the 85 fit any other years in that I have been working with dimensions of the supports only.
Thanks, Mr. Lou
Lift Supports Depot.com
07-25-2007, 08:19 AM
they are all the same. although if they are old and you fit a trd wing or such-like they wont take the weight.
07-25-2007, 09:32 AM
Or more precisely, model years 1983 thru 1987 on the liftback versions
of the AE85 and AE86 Corolla (SR5 and GTS in the USA) Tongue
Cheers... jondee86
  Effects of valve lift - worth it going higher? harkes 18 17,672 03-17-2014 09:21 PM
  Max lift on Vitz valve lifters harkes 9 11,531 01-02-2014 10:27 AM
  Problems installing yellow koni's in my TE71 liftback teun 12 16,327 11-09-2013 03:01 PM
Last Post: teun
  Rear ae86 rear discs & pad part numbers? J-86 4 6,163 11-30-2012 06:32 PM
Last Post: J-86
  Will ae86 stock springs fit TE71 liftback ? Ryo 19 26,797 05-04-2011 05:21 AM
Last Post: ash16valve
