Lift Supports Rear 85 Corolla 3 door liftback AE86
07-25-2007, 06:38 AM
Greetings: I have been working with an individual to find a good set of reasonably priced lift supports for the above model.. Can anyone tell me if the supports for the 85 fit any other years in that I have been working with dimensions of the supports only.
Thanks, Mr. Lou Lift Supports Depot.com |
07-25-2007, 08:19 AM
they are all the same. although if they are old and you fit a trd wing or such-like they wont take the weight.
07-25-2007, 09:32 AM
Or more precisely, model years 1983 thru 1987 on the liftback versions
of the AE85 and AE86 Corolla (SR5 and GTS in the USA) Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
Effects of valve lift - worth it going higher? | harkes | 18 | 16,996 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
Max lift on Vitz valve lifters | harkes | 9 | 11,223 |
01-02-2014 10:27 AM Last Post: Bean |
Problems installing yellow koni's in my TE71 liftback | teun | 12 | 15,959 |
11-09-2013 03:01 PM Last Post: teun |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,004 |
Will ae86 stock springs fit TE71 liftback ? | Ryo | 19 | 26,354 |
05-04-2011 05:21 AM Last Post: ash16valve |
