Lift Supports Rear 85 Corolla 3 door liftback AE86
07-25-2007, 06:38 AM
Greetings: I have been working with an individual to find a good set of reasonably priced lift supports for the above model.. Can anyone tell me if the supports for the 85 fit any other years in that I have been working with dimensions of the supports only.
Thanks, Mr. Lou Lift Supports Depot.com |
07-25-2007, 08:19 AM
they are all the same. although if they are old and you fit a trd wing or such-like they wont take the weight.
07-25-2007, 09:32 AM
Or more precisely, model years 1983 thru 1987 on the liftback versions
of the AE85 and AE86 Corolla (SR5 and GTS in the USA) ![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
Effects of valve lift - worth it going higher? | harkes | 18 | 17,797 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
Max lift on Vitz valve lifters | harkes | 9 | 11,563 |
01-02-2014 10:27 AM Last Post: Bean |
Problems installing yellow koni's in my TE71 liftback | teun | 12 | 16,356 |
11-09-2013 03:01 PM Last Post: teun |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,185 |
Will ae86 stock springs fit TE71 liftback ? | Ryo | 19 | 26,856 |
05-04-2011 05:21 AM Last Post: ash16valve |
