Lights - How to turn these on
07-13-2008, 10:15 PM
It may be a stupid question. How are these turned on? My Hachi Roku |
07-13-2008, 10:28 PM
light switch can be turned in 2 clicks.
1st click are those lights, second click are those light + head lights. could be that the flipping headlight have 3 clicks, dont know, but then the second click would popup the headlights. Im not too familiar with the trueno. |
07-13-2008, 10:41 PM
Ok thanks, they aren't coming on then. I've checked the bulbs for continuity and they are fine...
The fuse box has only a few fuses, all of which are fine... My Hachi Roku |
07-13-2008, 10:51 PM
dont know about the fuses, dont have a diagram for the ae86. but it could be missing. Are the rest of the electronics working? (dome lights, rearlights, etc)
07-14-2008, 12:17 AM
ok just been out to check.
All other lights are working fine. there is a connector that is 4 wires for sidelights, indicators and these lights. The plug. [code:1:d8468c0bcf] [GND][12v] [???][12v] Ignore this, this is wrong... ^ That connection goes to those lights. it doesn't get 12v, it constantly has 0.05v [/code:1:d8468c0bcf] Have a look at the attached pic. the inside lights seem to act as you said that the outside lights should... Any ideas. My Hachi Roku |
07-14-2008, 09:25 AM
hmmm, and when you turn on your turning lights or hazard light, do the white ones turn on/off?
07-14-2008, 10:15 AM
fog lights perhaps? (i'm not familiar with trueno/levin versions of foglights)
07-14-2008, 01:39 PM
I've turned all combinations of lights on and they don't light up...
But i am missing a switch from the car which i have now discovered is the fog light switch... i shorted the plug and the lights still don't come on... also tested continuity from that connector where the switch should be and the plug and there is nothing... if some one could confirm they are fog lights i'll rewire it... My Hachi Roku |
07-14-2008, 02:47 PM
well, since your turn indicator light turn on when city lights should be going on, i was hoping the city lights would go on when you turned on your indicator lights...
if so, then those wires would be swapped or the wrong lens is placed. it would be a very strange place to place foglight btw. them being so close to the corners. |
07-14-2008, 03:45 PM
It sounds more like it's wired like a zenki Trueno to me...
Maybe some Initial D fan wanted it to act like a Zenki? Anyway, this is how it should operate: So everything works normally on your car, except that the white part doesn't light up when engaging the turn signal. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,689 |
12-19-2021 11:58 PM Last Post: gh0st |
Start wont turn over after installing radio | MC_JP | 6 | 9,601 |
09-22-2014 11:13 PM Last Post: izanagi |
Are these modded TRD N2 flares? | 4000GT | 6 | 18,177 |
06-21-2014 12:16 AM Last Post: 4000GT |
What injectors are these? | Alex170984 | 4 | 5,763 |
08-05-2013 11:53 AM Last Post: jondee86 |
Prothane, are these any good? | Eric | 16 | 13,686 |
09-11-2011 05:17 PM Last Post: xgrapher |
