Lucky today
05-02-2011, 03:45 PM
Lucky today
I think anyway.
Went to start the car and it did'nt start first time, second attempt it turned over and then made a horrible noise from the engine. After a little investigation I discovered that the cam belt tensioner spring had come adrift and pierced the cambelt, it was trying to rotate with the belt The belt was very loose and had jumped a couple of teeth, I expected that but I had not expected the small stud that the tensioner pivots on to have come out completely. Anyone care to suggest a series of events for what happened here ? Lucky ? Just a new belt and spring needed. An analogue brain in a digital World |
05-02-2011, 06:22 PM
Lucky today
Pretty close call!!!
Had a similar thing a few weeks back. I had ingintion problems and took the covers of to see if the marks line up like they are supposed to. I found that my spring was loose, too! Just waiting to rip my cambelt into pieces. I was very lucky, too. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-02-2011, 07:53 PM
Lucky today
Ah so it's no an isolated case then.
I shall be keeping a very close eye on it in the future. What did you do with yours, new spring ? An analogue brain in a digital World |
05-02-2011, 09:21 PM
Lucky today
if you're running a stock 4age, nothing bad would have happened anyway.
05-02-2011, 10:04 PM
Lucky today
totta Crolla Wrote:Ah so it's no an isolated case then. I´d put in a new spring if my head was stock, usually change it with every belt. But I´d say it is an isolated case, cause I´ve got a massive skimmed head (talking about mm taken off by previous owner) I allways had to tighten the belt by hand to get decent tension, so I just ditched the spring. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-02-2011, 11:06 PM
Lucky today
Now there's a plan, I'm gonna ditch that spring too
I am going to change today spark's and coolant need help | Ryo | 8 | 6,790 |
06-25-2006 11:38 PM Last Post: PazzaAE86 |
Car died on me today, RIP fuelpump? | Ivan141 | 12 | 10,318 |
11-21-2005 11:54 AM Last Post: Ivan141 |
