MAP/AMF???
07-27-2006, 11:31 AM
MAP/AMF???
NoHachi Wrote:Not true. ITB's+ hot cams are the one situation where an AFM based setup would be infinately more easy to setup and tune. I think most of the hot cammed ITB engines run TPS based load sensing, not MAP based. As its very difficult to generate consistent and decent vacuum with the short trumpets. Either way, AFM would result in better fueling at the cost of slightly less power.
but then, as said, you would need an intake manifold.. to fit the AFM too... so not too easy as well Wink - TPS based is something different again... also you can run ITB without very hot cams (i.e ~256-264, maybe even 270) and still get decent vacuum...
  AFM to Map Conversion ps13michi 3 3,613 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,868 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 9,335 08-22-2016 10:01 AM
Last Post: ditn
  smallport question AFM or MAP? fax0815 5 8,627 05-17-2014 05:07 AM
Last Post: jondee86
  Tutorial : Megasquirting an European (MAP) AE86 (4age) gon 68 186,542 01-09-2014 11:23 PM
