MAP ECUs / Ignitors / Dizzy etc..
03-28-2008, 03:43 PM
Hi all.. Id purchased what is supposed to be a redtop (hicomp) MAP setup off a guy, received the box tonite from a buddy who picked it up for me and Im finding some weirdness that google and searching the forum hasnt helped..
Can anyone ID what I've actually got here: 2 ECU's.. 89661-20130 - can't find record of this anywhere, yellow connectors.. 89661-12130 - this appears to be a bluetop MAP ecu from the UK.. Dizzy - 19100-16040 - not the right-angle redtop cap Im used to, standard bluetop cap on it Coils / Igniters - 90919-02183 - Odd rectangular coil with small 2 pin connector in potting 19070-15120 / 89620-12270 looks like whats on the bluetop in my DD (not sure on part # tho) 89620-20241 and then a couple map sensors 89420-12010 89421-20040 Any help figuring out what Ive actually got here is appreciated.. Im supposed to be using it to run my hicomp redtop but Im thinking Im up the creek.. thanks, Brett |
03-29-2008, 12:56 AM
These are numbers from a JDM Hi-Com smallport...
90919-02198 Coil, encapsulated, two-wire plug 19100-16250 Distributor, wires from side of cap 89420-12040 MAP Sensor Cheers... jondee86 |
03-31-2008, 05:16 PM
great, thank you for the info..
Brett |
01-27-2009, 10:01 PM
89620‑20241 igniter of celica 4age 85-87
have you it? **COROLLA EE80 - 4AGE 124HP** ![]() |
AFM to Map Conversion | ps13michi | 3 | 3,442 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,509 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,124 |
smallport question AFM or MAP? | fax0815 | 5 | 8,487 |
05-17-2014 05:07 AM Last Post: jondee86 |
Tutorial : Megasquirting an European (MAP) AE86 (4age) | gon | 68 | 184,683 |
01-09-2014 11:23 PM Last Post: Bean |
