Megasquirt I v3.0 and toyota distributor/igniter
09-18-2009, 11:49 AM
Chrisso Wrote:I'm pretty sure the 2.89 code clears up the VR signal spikes are higher rpms. There's a post giving details in the ms general forum. msefi.com
Mines set up with as above, but I'm having serious comm issues and my trigger +/- is giving me the shits, rejecting ignition events.
Not sure if you mean the above as in the pics I posted with teeth removed, but if so be sure that you have removed the tooth all the way down to the base and not only the tip. A friend of mine did that mistake on a 1uzfte and had all kinds of trouble Tongue
'85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21
09-23-2009, 01:29 AM
Thanks morten. Yes, I did mean the same as your set up. My issue was a communication error between the MS and the laptop from using a USB to Serial adaptor. I've since swapped laptops and am using a proper serial port. All errors are gone, cranking RPM is rock steady at ~230 and everything else checks out. Hopefully have it running on the weekend.
10-02-2009, 01:19 PM
Engine start up but require alot of enrichments + throttle. So, if anyone has a VE table & spark advance they'd like to share it would be much appreciated! It would be nice to get a good idle and get it running well.
  How to test coil with igniter DJexor 2 8,856 03-22-2018 10:01 AM
Last Post: Project D
  16v distributor hole plug harkes 8 10,391 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 17,683 07-04-2016 03:27 PM
Last Post: Uzelac
  4age igniter question! Ghetto 1 5,395 01-09-2015 11:30 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 21,163 07-01-2013 11:08 PM
Last Post: pack
