Megasquirt I v3.0 and toyota distributor/igniter
09-18-2009, 11:49 AM
Chrisso Wrote:I'm pretty sure the 2.89 code clears up the VR signal spikes are higher rpms. There's a post giving details in the ms general forum. msefi.com Not sure if you mean the above as in the pics I posted with teeth removed, but if so be sure that you have removed the tooth all the way down to the base and not only the tip. A friend of mine did that mistake on a 1uzfte and had all kinds of trouble '85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21 |
09-23-2009, 01:29 AM
Thanks morten. Yes, I did mean the same as your set up. My issue was a communication error between the MS and the laptop from using a USB to Serial adaptor. I've since swapped laptops and am using a proper serial port. All errors are gone, cranking RPM is rock steady at ~230 and everything else checks out. Hopefully have it running on the weekend.
10-02-2009, 01:19 PM
Engine start up but require alot of enrichments + throttle. So, if anyone has a VE table & spark advance they'd like to share it would be much appreciated! It would be nice to get a good idle and get it running well.
How to test coil with igniter | DJexor | 2 | 7,634 |
03-22-2018 10:01 AM Last Post: Project D |
16v distributor hole plug | harkes | 8 | 9,275 |
10-12-2016 11:13 AM Last Post: harkes |
Changing distributor when carb 4age | izanagi | 14 | 14,969 |
07-04-2016 03:27 PM Last Post: Uzelac |
4age igniter question! | Ghetto | 1 | 4,778 |
01-09-2015 11:30 PM Last Post: Uzelac |
Distributor position and cranking | pack | 13 | 18,850 |
07-01-2013 11:08 PM Last Post: pack |
