Mocal oil cooler & sandwitch plate ordered
05-09-2008, 08:12 PM
F0Bman Wrote:Thermostatic valve does seem like a great idea, but the more moving partrs the less reliable . it is just a termostat.. nota moving part... cheers Roel I think I will order a kit if I know that the oil cooler is Moscal too... see like it though. the prices of http://www.biesheuvel.nl are far above this price.. cheers roel |
05-09-2008, 08:21 PM
Roel, a thermostat DOES move
05-10-2008, 10:30 AM
The Doctor Wrote:Roel, a thermostat DOES moveyeah by wax that is getting hot and expands.. but it is not a critacall part.. that is not exactly wat I call a moving part.. or should I order the part without termostat.. so the oil is allways running trough the oil cooler.. ?? it will save me 20 pound cheers roel |
05-10-2008, 11:06 AM
you can always do like i do ...
manual thermostat a cardboard is always in front of the oil cooler. I only remove it on track days but as in every manual thing you have to keep an eye on the oil temp to know if you need to remove the cardboard or not ..... |
05-10-2008, 12:44 PM
and what are acceptable oil temps for our 4ages???
AE86 FANATIC!!! |
05-11-2008, 11:37 AM
aceptable is around the 100 dgs Celsius like anny other cars..
above the 130 dgs most oils lose there function and get thin as water.. there is a castroll RS oil.. but will cost in stead of 6 / 8 L for normal oil 25 euro / L !! verry expensive oil.. |
05-13-2008, 12:02 PM
owkee.. If the cooler is an Mocal then I will order this Kit! with a 16 row cooler for the cooling cappacity.
Edit: He has got no more RWD sets in stock... But it is not that divers to a FWD type.. only thing I can come up to is the lengt of the hoses... Cheers, Roel |
05-13-2008, 03:29 PM
Mocal oil cooler & sandwitch plate ordered | |||
05-13-2008, 05:00 PM
thanx mate!!
will look there !! |
05-14-2008, 02:52 AM
If you have a look at my build file, you will see some photos including a remote thermostat
http://www.aeu86.org/viewtopic/parrots-s...highlight= |
Oil cooler | totta Crolla | 0 | 1,534 |
Oil cooler kit | izanagi | 7 | 8,551 |
Permanent oil cooler vs thermostat | Lt86 | 19 | 20,569 |
03-28-2015 06:54 PM Last Post: Lt86 |
trans oil, lsd oil change | Apolan | 9 | 16,921 |
Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 21,236 |
03-13-2014 11:45 AM Last Post: Rascal21 |
