Mux213 Levin GTS
07-02-2007, 04:51 PM
Post: #461
Mux213 Levin GTS
hey Bas!
nice to see your doing some nice things to your rollaWink
i finally got my ae86 booked in for some rust killing things in lithuania, so expect some pics, hopefullySmile
adam Wave
07-02-2007, 06:32 PM
Post: #462
Mux213 Levin GTS
Cool adam!
Glad you got the possibility to get her fixed up now! Hows life in the uk?
07-03-2007, 03:47 PM
Post: #463
Mux213 Levin GTS
hehe, yeah, finallyWink
hmm...im pretty shitty now, but will try to get myself outa this situation very soonWink Confused Cool
adam
07-28-2007, 09:14 PM
Post: #464
Mux213 Levin GTS
Hey Guys,
Just a small update. I installed Tokico HTS at the front a while back as you all know and was pretty happy with them so far. Factory however they are set to their highest setting which gives a very bouncy ride, far from optimum performance wise.
Because I had only ordered the fronts for myself I didn't get the adjustment tool with it, only Djex and CF have it but never got around to getting something to replace it and start tinkering with the settings.
Today I finally found out it takes a 6 sided 3mm allen wrench (I believe the proper word is, correct me if I'm wrong).
I was confused at first, I can't turn it to the right, because that tightens it, and I could keep turning it to the left.. Because you adjust the Tokico's when they are on the car and my car has pretty stiff suspension its hard to 'feel' the change with your hands. So I got very confused. I called up Djex and he told me that you can keep turning it to the left until you totally loosen the nut which is NOT good Smile According to the manual (which he hasSmile ) you're not supposed to turn it more then 8x anti clockwise from the hardest setting to the softest. He recommended I'd try 4 full turns first (half strength) and so I did.
And indeed, the ride difference is immense. Its no longer the shocks that are taking the brunt of the suspension work but the springs now nicely doing their job and the shocks doing their job. I finally decided on 3 full turns from strongest setting (so 5/8th strength) for now. Next week its track time and I'll start playing with it.
I really need to get these for the rears because I feel my current rear shocks (KONI) are set to high (or I'm hitting my bump stops atm, need to check that too) but I hate having to detach them to adjust them. HTS just is so much easier...
(we're getting some AGX shocks in soon I hope, maybe I'll mount a set of those rear, they are supposed to be adjustable on car aswell).
07-30-2007, 02:11 AM
Post: #465
Mux213 Levin GTS
great to hear that.. i think this is a very very fun phase in "hachilife" that you're in - now that your car is more or less "done" and you can start playing with different settings and test it and race it and really find the optimal setting. good luck!
btw, i vote for hts's. you just gotta have the same shocks maan if they are as good as people say. Smile
07-30-2007, 11:14 AM
Post: #466
Mux213 Levin GTS
Looking good Mux Smile
I'll try to be there next week too, already asked if there was any place left..just waiting for a response now. If I can drive too, then I'll take my camera+mount with me so we can try to get some hachi action footage as well Smile
07-30-2007, 11:48 AM
Post: #467
Mux213 Levin GTS
Michel,
that would be great! hope to see you thereSmile
09-02-2007, 10:57 AM
Post: #468
Mux213 Levin GTS
I always though our exhaust where 3 pieces, not 4....
Somethings not right there....
Just put my spare 2-1 on. Picked it up at Djexor. Was surprised that it still had heatshields completely in tact. Hope this one holds out longer then the old one... Interesting to see how it snapped right off... Atleast I can finally drive my hachi again after almost a month standing still...
09-02-2007, 11:54 AM
Post: #469
Mux213 Levin GTS
Who needs heatshielding? >Smile
09-02-2007, 01:10 PM
Post: #470
Mux213 Levin GTS
I badly need heatshield Huh
Honestly, when I drive bearfoot, not even in high RPM the heat in the car is burning my feet... the pipes are not even close to the body...
Is this normal? Undecided
Anybody solved the problem Dumb question
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
Lightbulb Deaty's GTS Project Deaty 9 5,249 04-27-2021 06:10 AM
Last Post: Deaty
  1985 Corolla GTS Project mattscar 5 10,753 01-30-2011 07:30 AM
Last Post: mattscar
  My SR5 to GTS Restoration Conversion. Lofty 15 19,847 09-25-2009 06:52 AM
Last Post: Lofty
  My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) ryceboy_124 4 22,657 08-05-2009 04:25 PM
Last Post: Eric
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 75,447 03-16-2009 10:02 PM
User(s) browsing this thread: 65 Guest(s)
