My 20v ITB installation
01-17-2005, 06:03 PM
Post: #41
I only have problems with 15 year old wiering looms that have been "repaired" over and over again. If I do it myself I can not see the problem with it. You just have to have a clear head and a plan when doing it.
01-17-2005, 06:12 PM
Post: #42
Wiring up a complete car takes TIME but doens't make stress. even when your not an electrician. it's not that hard, just make plans before you begin. and get 2 digital multimeters with PEEP function, they cost about $10 each so....
I did it 4 times now from the ground up, ie started with just 100meters of black 1.5mm2 wire and ended up with nice and tidy looms in the car 3 days later. make sure you've got the right tools though. wiring up the engine is the easy part believe me. getting park functions to work in wiper instalations with 2 different makes of parts, thats far harder to get right.
grtz Thomas
My car weighs only 496 kilograms with the 4age in place!
09-06-2005, 11:55 AM
Post: #43
Sorry to dig up this old thread, but Ian, can you take pictures of your TPS?
I'm building similar setup on Pero's ae86 and i would like to see how it's solved on your car.
Also do you know where do 2 additional vacuum hoses go (except to 4 throtles)?
Tnx
09-06-2005, 12:42 PM
Post: #44
Hey Zax,
the TPS sensor is mounted on the back ITB closest to the brake booster, There is a rod that runs straight through the casting to control the pair of butterfly flaps - think its just attached to that.
will hunt down the hoses for you - pretty sure 4 of them are collectors from the ITB castings, I think one goes to the brake servo/booster and another to the map sensor
I will do some proper hunting tonight for you.
Regards Ian.
[Image: AEU86 AE86 - My 20v ITB installation]
09-06-2005, 12:49 PM
Post: #45
Tnx Ian. Respect!
06-16-2007, 04:56 AM
Post: #46
if anyone is still around that originally posted this, or knows anything about this. i need to know about the hoses and what to do with them all! i dont understand!
06-18-2007, 02:19 PM
Post: #47
I think the hose all connect into a vacuum resevoir, for the map sensor, this is to stop vacuum pulsing from the individual throttle bodies. I linked all four of mine together with T pieces from a fish tank supplier., they through a old fuel filter to act as a resevoir. The car is at the rolling road so don't actually know if this works, but will keep you posted.
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
06-24-2007, 06:23 PM
Post: #48
I'll be trying something (just for fun and test) but I am gonne use the 16 tps sensor on the 20v itb and make it run on a standard 16v ecu. IF you mean the hoses form the itb's here's a list:
the first itb (with tps) has 2 lines one on the buttom and one on the top
Last one has 2 as well
2 and 3 have just one
so
1 and 4 have 2 air lines
2 and 3 just 1
mount the buttom ones to a resevoir and mount the resevoir to the MAP snesor.and if I check back with the 16v you can close the other 2 lines.
  4A-GE 20V ITB bolt patterns kjb 7 12,502 02-27-2016 01:23 PM
Last Post: kjb
  How to install 20V ITB on 16V head Mr.komp 7 12,232 12-28-2015 05:35 PM
Last Post: pack
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,278 09-15-2013 01:08 AM
Last Post: jondee86
  20v itb inlet manifolds totta Crolla 24 27,536 12-14-2012 12:21 PM
  4AGE 20v ITB vacuum instructions on Intecracing.com JAVResistance 17 34,912 05-07-2011 05:50 AM
Last Post: jondee86
User(s) browsing this thread:
