My 4AGE N/A build
01-14-2013, 06:35 AM
My 4AGE N/A build
I remembered about this thread the other day just thought id post the progress as its been a long year of ups and downs but finally got my engine together and will be up and running soon i hope just putting a loom together for the Megajolt ill be running it on.
Specs are like this now AWT polish and ported head with arrow shim under bucket kit with cat cam springs and Ferrea valves Toda adjustable pulley's Toda pistons with comp ratio of 11.3:1 Midwest Forged H-beam rods Toda 0.8 mm head gasket ARP head stud and nut kit Toda cambelt ACL race bearings New toyota pumps my Mikuni 45mm Carbs on the Ported and polished HKS inlet manifold Fujitsubo manifold Kakimoto exhaust Megajolt ignition Oh and decided to go with the Cat cams in the hope that this will keep it slightly more usable on the street. Apologies to oldeskewltoy too i forgot to get the head pics as it all went together. |
01-14-2013, 07:03 AM
My 4AGE N/A build
A stock clutch will easily hold the power you are looking to make. I have a stock clutch with a slightly heavy duty cover on a motor making 175WHP. Good drivability.
01-14-2013, 07:14 AM
My 4AGE N/A build
4000GT Wrote:A stock clutch will easily hold the power you are looking to make. I have a stock clutch with a slightly heavy duty cover on a motor making 175WHP. Good drivability. Wish i had known that before but i now have a Toda flywheel in there with a TRD clutch cover and a Helix 4 paddle disc. Probably best to run the paddle as it will be getting drifted pretty hard so id assume the clutch would suffer pretty bad. |
01-14-2013, 07:31 AM
My 4AGE N/A build
Lewy Wrote:4000GT Wrote:A stock clutch will easily hold the power you are looking to make. I have a stock clutch with a slightly heavy duty cover on a motor making 175WHP. Good drivability. Had a TRD cover with std disk before, worked fine, pretty much to the very end of the clutch disks, but since then I´ve changed to a helix paddle with sprung center and its a lot better no slipping and its either on or off. Every clutchkick a success, hardly noticed any wear and its a drift only car. Only thing that bothers me is the pedal travel to far up, might be cause I´ve mixed TRD and Helix, but as I said the biteing point hasn´t changed since new. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-14-2013, 08:58 PM
My 4AGE N/A build
Good to know its a good combonation of clutch parts as it will be getting used pretty hard for drifting and when i take part in Toyota sprint series events
Could the peddle not be adjusted ? |
01-18-2013, 03:13 PM
My 4AGE N/A build
If you are running a 212-215mm diameter flywheel the Toyota Corolla T-sport clutch is a direct fit those bad boys are rated up to 225hp.
01-18-2013, 03:50 PM
My 4AGE N/A build
Alex170984 Wrote:If you are running a 212-215mm diameter flywheel the Toyota Corolla T-sport clutch is a direct fit those bad boys are rated up to 225hp. Good to know thanks. I'll need one soonish. Is it the one for the 2ZZ-GE engine? AE86 ex-daily |
01-25-2013, 04:42 PM
My 4AGE N/A build
Alex170984 Wrote:If you are running a 212-215mm diameter flywheel the Toyota Corolla T-sport clutch is a direct fit those bad boys are rated up to 225hp. No im using a 200mm , but good to know for future reference |
7AGE Build | apardal | 5 | 718 |
08-02-2024 12:11 PM Last Post: apardal |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,828 |
NA Build Questions | Blue-/ Redtop questions | d3nso | 18 | 16,070 |
02-25-2013 07:01 PM Last Post: oldeskewltoy |
what bearings for my build? | Bean | 6 | 6,346 |
09-22-2012 10:25 PM Last Post: oldeskewltoy |
Doing a 7AGE build, gasket question | Snejk | 9 | 14,104 |
07-15-2010 12:42 PM Last Post: PetzK |
