My AE86 racecar project
08-08-2007, 05:28 PM
Post: #31
dAYTONA Wrote:Firstly, nice project.
Now, the fuel tank can be welded, but it needs to be free of fuel vapour. So it needs to be cleaned. There are places which specialise in welding fuel tanks, they clean them, weld them, paint them...you can also clean it yourself, and just weld up any holes.
I was looking for a super clean rust free fuel tank too... couldnt find one, then one day saw a add, guy had some spares for sale and I got a tank off him... still needs some work to avoid it having holes in the future, as it has some surface rust.
Good luck.
Thanks
I think it will be hard to weld it so it 100%, but maybe if you soldered it??
I also ordered a perfect condition tank so I kan get on with the project,
and then I'll see that to do with this one..
08-08-2007, 05:55 PM
Post: #32
Hi KrizKH
Could you tell me more about your gearbox conversion? I am looking for a close ratio gearbox for my KE70/4AGE track car. It looks as though you put an adapter plate onto the 4AGE bellhousing which will alow it to bolt to the M3 gearbox. Am I correct?
Which clutch and pressure plate will you be using? Which driveshaft will you be using?
Thanks.
08-09-2007, 01:18 PM
Post: #33
Kirby Wrote:Hi KrizKH
Yes. But also the "centre-ring" in the bellhouse, and the "male-part" fore the "centre-ring" on the gearbox is custom made..
nicely explained Huh hope you understand what I mean.
Quote:Which clutch and pressure plate will you be using? Which driveshaft will you be using?
- Flywheel and pressure plate is 4age, but flywheel is modifyed because the clutch is thinner.
- I don't remember where the clutch is from, but is was a special-order.. M3-Getragt / 4age (200mm) mix..
- The driveshaft is AE86 with M3-end welded on.
08-14-2007, 12:35 PM
Post: #34
Update.
I got another fuel tank but it had been laying without fuel too long so.. rust inside! Angry but I'll get it traded to another, so not a waste of money just time..
I got the 2.5 turns rack assembled and mounted on the car.
[Image: AEU86 AE86 - My AE86 racecar project]
pictures of the progress.. engine has been installed since.
The rusty parts will bee replaced anyway so I just use them as they are until.
08-14-2007, 01:34 PM
Post: #35
wat brakes are those on the front
looks hot
if first u dont succeed,ur not trying hard enough
08-14-2007, 02:10 PM
Post: #36
KrizKH Wrote:Brakes:
Front: HiSpec 300x28mm disc, 4pot calibers.
[Image: AEU86 AE86 - My AE86 racecar project][Image: AEU86 AE86 - My AE86 racecar project][Image: AEU86 AE86 - My AE86 racecar project]
They are from HiSpec Motorsport.
08-14-2007, 07:49 PM
Post: #37
put in a fuel cell? Costs around 300 euro's in NL you place it on your reserve wheel spot. New lines back to the original lines.
08-14-2007, 07:58 PM
Post: #38
looks good man
08-15-2007, 10:00 AM
Post: #39
robokill Wrote:put in a fuel cell? Costs around 300 euro's in NL you place it on your reserve wheel spot. New lines back to the original lines.
Yes I thourght of that!
But a fuel cell in the reserve wheel spot will place the weight of the fuel higher then the original and the original is an easy fit..
A fuel cell must be build in a box of some sort so it's shielded from the cabin.
I also thourght of lowering the boot and place a fuel cell but now that it's just painted I don't feel like cutting that much in the car.
08-16-2007, 07:59 AM
Post: #40
man those brakes are a work of art Big Grin
can i ask wat that valve does that comes off the line from the master clyinder
  ae86 racecar with beams engine bakonick 148 163,927 04-23-2024 10:06 PM
Last Post: bakonick
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 42,729 07-22-2019 02:55 PM
Last Post: apardal
  S.K.s AE86 racecar S.K. 207 222,564 09-18-2016 11:39 AM
Last Post: totta Crolla
  Firehawk's N2 racecar project firehawk 163 191,067 03-15-2010 08:28 PM
Last Post: Kid Karola
  Jonny's Levin Racecar Jonny Rochester 9 12,074 01-03-2010 04:34 PM
Last Post: woper
