My AE86 racecar project
08-08-2007, 05:28 PM
Post: #31
dAYTONA Wrote:Firstly, nice project.Thanks I think it will be hard to weld it so it 100%, but maybe if you soldered it?? I also ordered a perfect condition tank so I kan get on with the project, and then I'll see that to do with this one.. |
08-08-2007, 05:55 PM
Post: #32
Hi KrizKH
Could you tell me more about your gearbox conversion? I am looking for a close ratio gearbox for my KE70/4AGE track car. It looks as though you put an adapter plate onto the 4AGE bellhousing which will alow it to bolt to the M3 gearbox. Am I correct? Which clutch and pressure plate will you be using? Which driveshaft will you be using? Thanks. |
08-09-2007, 01:18 PM
Post: #33
Kirby Wrote:Hi KrizKHYes. But also the "centre-ring" in the bellhouse, and the "male-part" fore the "centre-ring" on the gearbox is custom made.. nicely explained hope you understand what I mean. Quote:Which clutch and pressure plate will you be using? Which driveshaft will you be using?- Flywheel and pressure plate is 4age, but flywheel is modifyed because the clutch is thinner. - I don't remember where the clutch is from, but is was a special-order.. M3-Getragt / 4age (200mm) mix.. - The driveshaft is AE86 with M3-end welded on. |
08-14-2007, 12:35 PM
Post: #34
Update.
I got another fuel tank but it had been laying without fuel too long so.. rust inside! but I'll get it traded to another, so not a waste of money just time.. I got the 2.5 turns rack assembled and mounted on the car. pictures of the progress.. engine has been installed since. The rusty parts will bee replaced anyway so I just use them as they are until. |
08-14-2007, 01:34 PM
Post: #35
wat brakes are those on the front
looks hot if first u dont succeed,ur not trying hard enough |
08-14-2007, 02:10 PM
Post: #36
KrizKH Wrote:Brakes:They are from HiSpec Motorsport. |
08-14-2007, 07:49 PM
Post: #37
put in a fuel cell? Costs around 300 euro's in NL you place it on your reserve wheel spot. New lines back to the original lines.
08-14-2007, 07:58 PM
Post: #38
looks good man
08-15-2007, 10:00 AM
Post: #39
robokill Wrote:put in a fuel cell? Costs around 300 euro's in NL you place it on your reserve wheel spot. New lines back to the original lines.Yes I thourght of that! But a fuel cell in the reserve wheel spot will place the weight of the fuel higher then the original and the original is an easy fit.. A fuel cell must be build in a box of some sort so it's shielded from the cabin. I also thourght of lowering the boot and place a fuel cell but now that it's just painted I don't feel like cutting that much in the car. |
08-16-2007, 07:59 AM
Post: #40
man those brakes are a work of art
can i ask wat that valve does that comes off the line from the master clyinder if first u dont succeed,ur not trying hard enough |
ae86 racecar with beams engine | bakonick | 148 | 163,895 |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 42,724 |
07-22-2019 02:55 PM Last Post: apardal |
S.K.s AE86 racecar | S.K. | 207 | 222,544 |
09-18-2016 11:39 AM Last Post: totta Crolla |
Firehawk's N2 racecar project | firehawk | 163 | 191,048 |
03-15-2010 08:28 PM Last Post: Kid Karola |
Jonny's Levin Racecar | Jonny Rochester | 9 | 12,073 |
01-03-2010 04:34 PM Last Post: woper |
