My Revised '80's Thrashbox
09-18-2009, 10:12 AM (This post was last modified: 04-30-2015 02:04 AM by OnBail.)
Hi fellow AE86 proud owners.
Good to see the strength of the 86 on your side of the planet doing well.
So far I am on my 3rd AE86 now (2nd one in Japan) and I ended up with this.
It's still not where I really want it so it's still a work in progress.
I'm sure that some here might have already seen my car on other forums from past and recent.
Car specs (Last updated in April 2015)
Base: Toyota Corolla Levin
Chassis: AE86
WHEELS
Watanabe Racing R-Type 14" x 9.0J @Front
Watanabe Racing R-Type 14" x 9.0J @Rear
ADVAN NEOVA Tires for Front
NEXEN Cheapies for Rear
Super Lightweight Duralumin Race Wheel Nuts (Some Japanese brand which I forgot)
HBK 20mm longer wheel studs
BRAKES
ENDLESS CCA Brake Pads
Vented & Slit Disc Rotors all round
RUN MAX Braided Brake lines
SUSPENSION
BC Coilovers (for now, will get the dampers custom re-valved later or go with a DG5 setup)
Cusco Adjustable Tension Rods (Caster Rods) with the Cusco reinforced mounts as well
Nagisa Auto Adjustable Inner Tie Rods
Nagisa Auto Adjustable Pillow Ball Outer Tie Rods
TRD Reinforced Bushes
TRD Rear Sway bar
TRD Bushed Upper Rear Control Arms
Custom made Pillow Ball (Rose Jointed) Adjustable Super Thick Custom Lower Control Arms
DRIVE TRAIN
OS Giken STREETMASTER Single Metal Clutch with Chromoly Flywheel (2011 released model)
Run Max Braided Clutch Line
TOMEI Technical Trax 2 Way LSD
4.778 Final Drive Kit (with 5.375 TRD ratio spare)
Brake Booster removed (was in the way of the 100mm trumpets)
ENGINE (New spec built by KAI ENGINEERING in Kanagawa, Japan)
AE92 base
Compression Ratio 12.8:1
Bore : 81.0mm
Stroke : Stock 77.0mm
Managed by Haltech Platinum Sport 1000
Engine loom is now all Haltech Autospec Flying Lead Kit Long
AE101 Throttle Bodies
Tec Arts 100mm trumpets
Techno Toy Tuning 4AG ITB Billet Adapter plate
TOMEI PROCAMS Camshafts INTAKE: 288 x 10.0mm Lift / EXHAUST: 280 x 10.0mm Lift (Custom made by Suzuki-san, the younger brother of the founder of Tomei Powered Inc.) I also custom made the lazer marking on the cams myself at Tomei.
TOMEI Adjustable Cam Gears
TRD 0.8mm Metal Head Gasket
TRD Valve Springs
Formula Atlantic Spec Cross forging Forged Pistons
Tomei Fuel Pressure Regulator Type-S
Tomei Fuel Pressure Gauge
Trust Oil Cooler Kit (removed during winter)
Aftermarket 4-2-1 headers
Toda Racing Exhaust System (with the Toda decat pipe)
BODY
RUN FREE Fiberglass Front Bar
RUN FREE Fiberglass Front Fenders (guards)
RUN FREE Fiberglass Side Steps
RUN FREE Fiberglass Rear Bar
CBY Fiberglass rear hatch with the stock dampers (many other makes in Japan don't have this)
Unknown Fiberglass Bonnet
CUSCO 5 Point Roll Cage
INTERIOR
PRO DRIVE Japan deep type Steering wheel
Recaro Bucket Seat (Driver Side)
Bride Reclineable Bucket Seat (Passenger Side)
Omori 52mm Oil Temp Gauge
Omori 52mm Oil Pressure Gauge
AEM Digital Wideband Air / Fuel Gauge
TRD leather Shift Knob
[Image: AEU86 AE86 - My Revised '80's Thrashbox]
ok here are some extra images on my car with the engine bay and a bit more
most are old and I know the engine bay needs a good tidy up too.
-- JailBait --
Bait me!
09-18-2009, 11:23 AM
Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie!
[Image: AEU86 AE86 - My Revised '80's Thrashbox] http://www.jdmbits.com
09-18-2009, 11:46 AM
nmwisima Wrote:Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie! Yummie!
That about sums it up: location, road quality, car, friends' cars...
09-18-2009, 03:42 PM
Very very very very very cool levin! Yummie!
Hmmm, featuring a newera imports sticker? Don't tell me Miguel re-imported it back from Ireland!? >Smile Big Grin
09-18-2009, 03:44 PM
your levin is so cool
AE86 owner
09-20-2009, 08:30 PM
thanks guys
banpei, no this car never left Japan. Miguel and I are good friends and I have had this car since 2006.
It's still a work in progress!
-- JailBait --
Bait me!
09-20-2009, 08:38 PM
hope one day i can go to japan and cruise with you guys
AE86 owner
09-22-2009, 10:14 PM
been a while since you posted man Tongue did you forget your Mosqiton login? lol car looks cool as hell Evil
What are the offsets -13 and -19 respectively? Are the rear arches RunFree overfender flares blended in or custom flared metal? Love how they match to the kit perfectly Thumbs up! Cheers
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
09-23-2009, 11:47 AM
Kid Karola Wrote:been a while since you posted man Tongue did you forget your Mosqiton login?
LOL! Big Grin
I already thought the hachi looked familiar! Wink
Maybe use the "I forgot my password" functionality?
09-25-2009, 03:49 PM
yes I was MoSqiToN but got bored of that name so figured I'd change it. I wanted to keep the same name on other boards and I like this name better.
These days I have a little more time to check forums again so starting off fresh
-- JailBait --
Bait me!
