My Ride
03-23-2012, 12:50 AM
Post: #231
My Ride
almost start the engine have to check injectors wiring I'm so JDM I put everything sideways. AE86 owner |
04-05-2012, 09:14 PM
Post: #232
My Ride
it lives .....
need to work on vacum tubes to get a nice running engine I'm so JDM I put everything sideways. AE86 owner |
04-24-2012, 01:28 AM
Post: #233
My Ride
07-25-2012, 01:29 AM
Post: #234
My Ride
08-07-2012, 12:53 AM
Post: #235
My Ride
some test for 86 day
my clutch slips... diff need tune and some more bits I'm so JDM I put everything sideways. AE86 owner |
08-07-2012, 02:11 AM
Post: #236
My Ride
Tune your front axle, you loose too much grip when you initiate your drift.
(Maybe your tyre pressure is too high on the front) Also your suspension seems too soft (we can see it bouncing) |
08-07-2012, 07:22 PM
Post: #237
My Ride
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
08-07-2012, 07:47 PM
Post: #238
My Ride
yea the rear seems to bounce all over the place. But i saw quite few good drifts, with a little tune it will be awesome.
ハチロク |
08-07-2012, 11:13 PM
Post: #239
My Ride
the front is soft and tire has some pressure
e have to see the problem with the clutch I'm so JDM I put everything sideways. AE86 owner |
08-08-2012, 12:10 AM
Post: #240
My Ride
so my problem
i got a 4 kg flywheel and exedy stage 2 and the clutch slips at full pedal or under 4000rpm.. since the 4AGZE has almost 10kg flywheel is it the fast spin the problem? in the pic there is my old flywheel an press plate with a contact area of 222mm has the oem clutch plate has 220mm the almost new one is the exedy stage 2 press plate with have a contac area of 210 mm and the exedy clutch plate is 200mm. also the 4 kg flywheel as the same area 200mm. just to test i will get the 86 std flywheel and press plate fitted with the exedy clutch plate i got the 4kg and exedy kit 2 year ago so they are like brand new also opened my diff and the pinon and ring were ok and the backlash was fine but the diff made mutch noise when hot and shake the rear end of the car when the kaaz 2 way was was opened it was full of tiny micro sand type due to the many disks of the lsd. it was blocking some oil holes so i hope it will be fixed when cleaned now it is on a lsd oil bath to get the disks soaked hope to get news soon I'm so JDM I put everything sideways. AE86 owner |
Scrapper's ride | Scrapper | 30 | 33,218 |
09-28-2012 05:18 AM Last Post: kennedy8383 |
User(s) browsing this thread: 118 Guest(s)
