My cluster shows wrong speed.?
03-10-2008, 05:44 PM
Ah that explains a lot!
SR5 got 4.1, so 4.88/4.1 = 119! 19 -> 22 will solve it almost, you can do the rest with the tiresize. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
03-10-2008, 06:35 PM
thanks alot!
DonĀ“t Think About The Past, Live In The Present And Dream About Tomorrow |
03-11-2008, 09:50 AM
Allexz Wrote:ive have the volvo 240 rear axle w the 4.88 in ratio Photos please ! |
03-11-2008, 08:26 PM
Check SK's project for pics of a volvo 240 axle on a hachi..
03-14-2008, 03:10 PM
Thanks !
I have 240 rear axle 1030 type bought for another car, good to see that it fits nicely ! Is it true that all Dana 35 CWP and LSD options will fork for it ? |
03-14-2008, 03:45 PM
Dana 30 if I'm not mistaken.. If it's a 1030 then the R&P will fit, if it's the later 1031 axle, then you can only use the diff cause it has beefier R&P gears.
If your looking into this, could you possibly find out what the difference is between the DANA diffs for different ratio R&P's? They have 2 models, one goes up to 3.6 or 4.0 ratio, and the other one for higher ratio's. My volvo 360 has a 1031 style rear diff, so it would be interesting to know what to look for, and if there are differences that I should look out for. FABRICA MI DIEM, PVNC! |
03-14-2008, 03:53 PM
Ivan141 Wrote:Dana 30 if I'm not mistaken.. If it's a 1030 then the R&P will fit, if it's the later 1031 axle, then you can only use the diff cause it has beefier R&P gears. So the question is about 2 models Dana 30 diffs - up to 4.0 ratio and over it ? What is the difference, compatibility for CWP also ? Yes, I'm sure my rear end is 1030, I bought it exactly for Dana max. compatibility in order to use cheap options from USA |
03-17-2008, 12:38 PM
I asked in local Jeep forum and the answer was:
Quote:For Dana 30 and 35: |
03-17-2008, 07:33 PM
So which one matches the volvo unit size-wise? I'm pretty sure volvo used one type of lsd for the whole range of r&p ratio's, at least they did on the 360's with 1031 diff (which should be the same as a 1030 but with beefier bearings on the pinion gear, and thus different r&p sets).
03-18-2008, 10:26 AM
They are Jeep community and know nothing about Volvo, I suspect that I must measure/compare my Volvo 1030 diff with some Dana 30 from their offroad cars.
EUDM gauge cluster | banpei | 22 | 4,408 |
EUDM cluster revelations | banpei | 1 | 1,257 |
06-23-2023 09:11 AM Last Post: r.ave |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,315 |
Custom Dash Cluster | kazi | 14 | 20,080 |
EDM GT-S Cluster, PWR light VSV? | Rascal21 | 1 | 3,972 |
06-25-2017 08:00 PM Last Post: Rascal21 |
