NEED HELP!
08-16-2005, 04:36 PM
NEED HELP!
I want to know if i have spare rim 14" what tire i must use on it.
The car is on 15" 195/50 tires.
85' AE86 GT coupe lifetime project since 2005
08-16-2005, 04:48 PM
NEED HELP!
google on "tire size calculator" you should find a nice applet that tells you everything you would ever want to know.
08-16-2005, 05:59 PM
NEED HELP!
I think 185 60 14, but you should check the tyre calc to be shure...
Andrej
08-17-2005, 07:53 AM
NEED HELP!
No problem to use even 155/60/14 as a spare. The spares are not permanent type of wheels - so this is not an issue - you should not match this tyre size with others.
08-20-2005, 11:43 PM
NEED HELP!
Thank's guys!
Btw. i also need to know what tires i can fit on atiwe 15" rims... any idea?
If i can use some bigger (example 195/55 R15) but so that they don't rub the wheel arch. On srapyard here are plenty good 195/55 tires with good depth. Dunno why but 195/50 are most used tires here so are less avaiable on srapyards.
08-21-2005, 12:30 AM
NEED HELP!
i run 205x50x15 on my hachi :-)
rims are offset/et +21
  Need help identifying this! takumi_mt 4 898 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 3,801 02-18-2022 10:42 AM
Last Post: ps13michi
  Need some help DJexor 4 5,273 03-13-2018 05:37 PM
Last Post: pack
  JDM trueno not starting. need help! kazi 8 8,678 03-12-2017 05:05 PM
Last Post: kazi
  Stack display system, need help Jimmi The Kid 1 4,196 01-15-2017 10:52 PM
