Needed HELP!
07-20-2008, 08:53 PM
Needed HELP!
Try to look for complete engine rebuild gasket kits.
for AE86 blue top 16V 4AGEC.
Can someone help me or feed some info where can I get it?
Your help is much apperciated.
Thanks in advance.
07-21-2008, 09:13 AM
Needed HELP!
Toyota has full rebuild kits, but aftermarket shops like brezan have non OEM as well.
[Image: AEU86 AE86 - Needed HELP!]
07-21-2008, 12:40 PM
Needed HELP!
I suggest to use the geniue Toyota kit. It is a bit expensiver, but it's worth
You can get it at Passracing for example at a reasonable price.
Daily driver: AE86 - 1985 zenki levin
07-22-2008, 08:33 PM
Needed HELP!
I also STRONGLY recommend the factory AE86 engine overhaul kit. Check with your dealer.
There is one odd absence in(or not in) the factory kit... the 8 cam cover seals/washers are not in the kit, they must be purchased seperately
Dan -
07-29-2008, 05:09 AM
Needed HELP!
Yes look on ebay they have generic engine kits made by fel pro .
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Help needed totta Crolla 3 4,109 05-15-2020 10:07 AM
Last Post: totta Crolla
  Some wiring help needed DJexor 5 5,743 05-18-2019 01:50 PM
Last Post: DJexor
  Help needed: is it 1 way or 1.5way LSD Dino86 2 3,837 05-17-2019 09:08 AM
  Help Needed with steering. phill 92 1 6,661 10-18-2013 02:58 PM
Last Post: fax0815
  Help needed with door mirror glasses T_AE86 3 5,263 06-29-2013 01:16 AM
Last Post: T_AE86
