Needed HELP!
07-20-2008, 08:53 PM
Needed HELP!
Try to look for complete engine rebuild gasket kits.
for AE86 blue top 16V 4AGEC. Can someone help me or feed some info where can I get it? Your help is much apperciated. Thanks in advance. |
07-21-2008, 09:13 AM
Needed HELP!
Toyota has full rebuild kits, but aftermarket shops like brezan have non OEM as well.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
07-21-2008, 12:40 PM
Needed HELP!
I suggest to use the geniue Toyota kit. It is a bit expensiver, but it's worth
You can get it at Passracing for example at a reasonable price. Daily driver: AE86 - 1985 zenki levin |
07-22-2008, 08:33 PM
Needed HELP!
I also STRONGLY recommend the factory AE86 engine overhaul kit. Check with your dealer.
There is one odd absence in(or not in) the factory kit... the 8 cam cover seals/washers are not in the kit, they must be purchased seperately Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-29-2008, 05:09 AM
Needed HELP!
Yes look on ebay they have generic engine kits made by fel pro .
Help needed | totta Crolla | 3 | 4,060 |
05-15-2020 10:07 AM Last Post: totta Crolla |
Some wiring help needed | DJexor | 5 | 5,674 |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,791 |
05-17-2019 09:08 AM Last Post: Ivan141 |
Help Needed with steering. | phill 92 | 1 | 6,630 |
10-18-2013 02:58 PM Last Post: fax0815 |
Help needed with door mirror glasses | T_AE86 | 3 | 5,223 |
06-29-2013 01:16 AM Last Post: T_AE86 |
