(New) Rear Brake Disc Width
07-06-2010, 04:26 PM
I have been searching all over the net for this with no luck... Does anyone know the figure?
Thanks!
SFD
07-06-2010, 08:04 PM
i will messure mine tomorow or day after...
they have ess then 100km so like new...
07-06-2010, 08:06 PM
iirc it's 10mm
EDIT: just checked the manual front is 18mm (17mm minimum) and rear is 10mm (9mm minimum) Wink
You can find the manual on the frontpage in the Technical section (left lower side) helps a lot for things like that and more. Wave
07-06-2010, 09:56 PM
Thanks! Stupid me, didn't occur to look at the most obvious place! Banging head
I guess for 0.4mm it won't be a problem to fit a wilwood dynapro-2pot in the rear (says disc max width 9.6mm) I don't suppose anyone in the forum has done a similar modification?
SFD
07-06-2010, 10:04 PM
not done that modification but in worst case you will need to skim down the pad slightly if you can't fit the caliper over the disc Wink
  Axle width totta Crolla 1 3,451 10-24-2023 12:20 PM
Last Post: FanIsHere
  Switching diffs for disc brakes? trippin 6 6,495 07-08-2022 03:35 AM
Last Post: trippin
  Rim width. Which is best.... Dino86 5 9,848 01-07-2017 03:09 PM
Last Post: Dino86
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 5,374 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 13,178 10-18-2016 11:50 AM
Last Post: fantapants
