Nomukens humble AE86 project
05-24-2011, 08:50 AM
Post: #91
If I remember right it was something like this. VVT is shifting about 15°!?
So with the engine on the stand, I skipped one tooth on the belt (10°) and simulated the othe 5° with an adjustable cam pulley that I have layin around. Then turned the engine by hand.
You may also just skip 2 teeth on the belt. Turn the engine by hand,... If nothing touches you're definately on the safe side!
http://monkeymagic86.wordpress.com
05-24-2011, 11:02 AM
Post: #92
Thanks man,
to be clear, VVT is working on my car just fine with the kelford cams and I was curious how you tested it. I was told to take off the head and place putty on the piston, or use compressed air in the oil galley that feeds the VVT pulley while turning over, and I like your method as well!
I was asking because I feel that my intake cam could be advanced just a tad to provide better driveability ...but that would make the valve become even closer to the piston when VVT is turned on.
What was damaged on your bottom end?
05-24-2011, 11:05 AM
Post: #93
Rod bearing failure that damaged the crank.
Same thing on 20V engine #2, different block and crank, new bearings,...
05-24-2011, 11:17 AM
Post: #94
Please tell the Jacobies, I want one of those wheel sets Thumbs up!
[Image: AEU86 AE86 - Nomukens humble AE86 project] http://www.jdmbits.com
05-24-2011, 11:28 AM
Post: #95
the minilites or the sakuras?
05-25-2011, 09:37 AM
Post: #96
I've been going through your blog for the first time, very cool! Lots of pics of corollas I haven't seen before. Keep up the good work!
05-25-2011, 11:21 AM
Post: #97
Nomuken Wrote:the minilites or the sakuras?
The Gold ones. I need one set shipped to me Smile
05-26-2011, 11:30 AM
Post: #98
Just a new pic from last friday to tease you. Might be the best action shot of my car so far!
Uploaded with ImageShack.us
05-27-2011, 09:41 AM
Post: #99
Will post it to the blog! Thumbs up!
05-27-2011, 05:07 PM
Post: #100
love it
AE86 owner
