OST-032: Skippy gets a head
05-29-2015, 04:41 PM
great job
what tool do you use to polish/work the surface? |
05-29-2015, 04:59 PM
(This post was last modified: 05-29-2015 05:00 PM by oldeskewltoy.)
(05-29-2015 04:41 PM)AlexKTM Wrote: great job thanks........ as to what tools I use... carbide burrs, sanding drums of various diameters, abrasive paper - 220, 320, 400, Dremel Buffs, and polishing paste....... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-19-2015, 03:12 AM
So... Skippy's head is back and it carries a fresh 3 angle valve job, and a minimal machining - .004".
I only had the head cut .004" so I could keep some of the deshrouding volume - target chamber volume of 36.5cc. I did this so I could keep the static compression high, but manageable @ about 10.7 to 1, and tighten the squish gap by about 20% Specs 3.209" bore, 3.0315" stroke, .036 gasket, deck is .001 (under), piston volume 2/10 of a cc crown, with a 36.5cc chamber. preparing to check chamber volume.... note the wooden shims under the head to get it at a slight angle ![]() measuring chamber #1.... ![]() and the result......??????? Bullseye 36.5cc!! ![]() The chambers are now perfect, Skippy's head is now ready for reassembly.... ![]() "Perfect"? It appears that chamber #4 is tight, or so it seems in the photo. It WAS a bit tight, I worked the chamber walls a little adding a 1/10 of a cc to the chamber. This was a partial head when I began, the valves in this head were not originals to this head, so in this case although being re-assembled, I fully expect SOME dis-assembly of the valves for those needing to be tipped. More to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-20-2015, 01:30 AM
oldeskewltoy Wrote:This was a partial head when I began, the valves in this head were not originals to this head, so in this case although being re-assembled, I fully expect SOME dis-assembly of the valves for those needing to be tipped. I managed to get the intake set... a few thin shims were needed. the exhaust side is another story... #1 valve, even with the thinnest shim I had was still a no pass, so I'm planning on taking a "big swing" @ the tip of #1... a few others are almost as bad.... ![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-24-2015, 07:17 PM
from another forum Wrote:I had to tip the valves on the head I just rebuilt for my FX16 after the valve job. You can also do the same with the shims...... I have about 100 3.0mm shims... thinking of using the shops shim grinder, and then finish with 1000... make my own batch of thin shims - down to 2.3mm or so from another forum Wrote:Hey OST, Great question! Many people have earned their masters, or doctorate writing on this very subject. My education in the subject began when I built the engine for Surreptitious. Using the TRD Bible as a guide, I worked the combustion chambers to minimize all the sharp edges caused by the factory machining. I then brought the head to Loynings Engine Service... a well known Formula Atlantic builder. It was there I began to build a relationship with the shop. I was allowed in, and allowed to see the Atlantic heads upclose. I spoke to their lead head porter and he gave me some advice and offered some guidance. The rest I've gleaned from many other sources..... I'm a member of a number of forums where I'm the one doing most of the learning ![]() The 2 theories... a) are nearly moot when discussing a 4AGE. This is because the fuel is only added directly above the valves in a 4AGE, in a carbureted application this might be more of a concern since the air and fuel are mixed and travelling through the ports together... BUT Most people who argue/discuss atomization, or laminar flow tend to minimize the effect of the dynamics of an engine. These dynamics are the airflow is NOT consistent... the airflow in an engine is dynamic it moves toward the valve, stops, moves a little away, and then moves toward/past the valve into the engine. This means the air stream is not flowing, but is more like the dance called the bunny hop... 3 steps forward, 2 steps back.... It is harder to say it helps atomizes, or laminar flow when the airflow is not smooth, but buffetted. b)removing too much material from the chamber is a bad thing... you lose something called port reversion but removal of some material is required so you can remove hot spots from the chamber that cause ping/pre-ignition. A simple explanation of port reversion is a valve opening inside a funnel, the valve opening is always a metered opening thus keeping velocity up as the valve opens. So it is a trade off, the fact that the 4AG head is cast as it is means there is more advantage to CAREFUL material removal so that compression can be raised increasing the engines ability to make power. Port reversion tends to lessen as the valve angle increases. Port reversion works great on GM's LS series, or other engines were the valve angle is less then 15 degrees, the effects of port reversion lessen as the valve angle increases. The 4AGE has steep valve angles. Now as far as my bowl and seat work, I'm mostly fixing flaws that occur because the head is a mass produced part destined for corporate profit, so flaws creep into the equation. I remove the flaws. Now as an example of why flaw removal is important, someday watch a stream, or brook, watch how the water interacts with the stream bank, watch the eddy currents, now watch a water slide... no eddy currents.... So, I've discussed the bowls and seats, and chamber deshrouding... but I have not yet discussed my exhaust port re-taper.... Quote:I was allowed in, and allowed to see the Atlantic heads upclose. ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-28-2015, 09:56 PM
That's just awesome, I wish we had something close to that here
So envy right now hahaha keep up the good work! |
06-30-2015, 05:01 PM
(06-28-2015 09:56 PM)AlexKTM Wrote: That's just awesome, I wish we had something close to that here I ship world wide...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-30-2015, 05:31 PM
YOu need to make me a decente 20V head =D
03-24-2016, 08:45 PM
![]() ![]() Numbers are @ the wheels, back calculating with a 14% drivetrain loss that is about 140hp and 125#/ft at the crank. dyno run - http://ost.ebeans.ch/albums/userpics/100..._120hp.mp4 (06-30-2015 05:31 PM)pack Wrote: YOu need to make me a decente 20V head =D I've done a few 20V heads since you asked.... **IF** you are still interested..... http://www.aeu86.org/forum/showthread.php?tid=14852 http://www.aeu86.org/forum/showthread.php?tid=14815 Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,554 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,916 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,364 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,159 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,716 |
