OST-040: BOOOOSTed
08-16-2016, 10:37 PM
OST-040: BOOOOSTed
oldeskewltoy Wrote:all that is left to do... is set cam - valve clearances......
the cam sheet... with the the valve opening and closing events laid out....
[Image: AEU86 AE86 - OST-040: BOOOOSTed]
9.4mm of lift is getting close to requiring clearancing the head so the lobes don't hit.... but not quite
setting clearances... spec is .20mm(.008") on the intake side, and .25mm(.010")... a thousandth is within tolerance.
Final questions: What is actual valve lift on exhaust valve #4?? And on #3 exhaust valve?
This head is now done, and will be heading back to it's owner shortly.....
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,311 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,312 09-18-2022 02:19 AM
Last Post: oldeskewltoy
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,025 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 1,932 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,530 06-28-2022 09:17 PM
