OST-044: What the "F"?
06-09-2017, 01:38 AM
(This post was last modified: 06-09-2017 01:38 AM by oldeskewltoy.)
It has been a while since I did an "F" head, Grunt's lump was built Dec 2010 to June 2011 - F head port, and rebuild
This "F" head is a later type, with the raised intake ports. Time to get it cleaned and pressure checked current short radius..... more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-09-2017, 09:28 AM
(This post was last modified: 06-09-2017 10:21 AM by ditn.)
interesting,do you mean a 4afe?
a friend of me has one in his celica and is looking for cams etc. from what i have heard 4afe is also a great engine but parts support isnt there and it need tons of headwork |
06-09-2017, 05:17 PM
(This post was last modified: 06-09-2017 05:18 PM by oldeskewltoy.)
(06-09-2017 09:28 AM)ditn Wrote: interesting,do you mean a 4afe?Yes.... 4, or 7 AFE as to parts supply, there are a few companies who can make you cams... biggest issue there is the slave driven intake cam off the exhaust cam, and trying to adjust them independently.... Which head does he have? The first "F" head I worked was an early one with crappy ports, this one is cast much better. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-20-2017, 11:19 PM
from another forum Wrote:Those 2nd gen intake ports are so steep. That they are..... The intake valves are also bigger, 1st gen 30mm, 2nd gen 31mm That is the extent of the good news... the bad news.... the front oil drain still interferes with the exhaust flow on #1 exhaust port more to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-20-2017, 11:36 PM
That's quite a big difference in amount of material that you can remove between #1 and #4
06-22-2017, 02:39 PM
he has the latter head
06-23-2017, 04:07 AM
What do I see........????
06-23-2017, 09:24 PM
(06-23-2017 04:07 AM)oldeskewltoy Wrote: What do I see........???? While you are still trying to see what I see.... 7 years ago when I built "Grunt's Lump, OST-011", I didn't have the easiest(best?) tool for setting, AND measuring the valves....... Here is the design, and building process for the tool I'll be using this time..... quite a bit more accurate and reliable! more to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-26-2017, 08:35 PM
(This post was last modified: 06-26-2017 08:51 PM by oldeskewltoy.)
(06-23-2017 04:07 AM)oldeskewltoy Wrote: What do I see........???? wider valve spacing on the exhaust valves..... although not clear enough to measure in the photo, if you look at the cam journals, the intake journal is about 2mm narrower then the corresponding exhaust cam journal more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-06-2017, 04:33 PM
So it has been a while.... and after some digging..
there is improvement to be found.... more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,261 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,117 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,933 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,886 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,498 |
