OST-044: What the "F"?
07-11-2017, 01:18 AM
intake side just about finished......
![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-11-2017, 12:45 PM
Stunning work as always
![]() Daily Beater: Civic EG5 Work in progress Car: AE86 |
11-15-2017, 06:13 PM
from another forum Wrote:I'm guessing there will be a custom intake manifold for this? Or is the customer going to run with the stock one? I was trying to convince him to run something custom(similar to a stock SR20DE intake), but for now he is retaining the OEM intake. Valve Springs Wrote:I really wish all my clients were as diligent as this one - My client is one who has done his research..... ![]() The bottom end showing the MRP rods. ![]() A point - these rods did need a bit of work to be used. The big end of the rod had some taper (.001"), and the IDs were inconsistent - varied by .0008".... but they are still far less costly then getting them from Carrillo. While there was some issues to be addressed, these issues were caught, and CORRECTED by a professional race shop! ![]() Finally, I've been finishing the head, getting the "new" intake cam to fit, and getting the "new" exhaust valves to fit the best of the exhaust cams I have. Some were done with shims, while others had the valve "tipped" a few ten thousandths. more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-27-2017, 08:03 PM
from another forum Wrote:The MRP rods are also slightly longer than the standard 7A rod aren't they? To be honest... I can't confirm, or deny that... Here is what I know........... the deck of the block was slightly damaged, requiring machining to make sure the metal gasket sealed. ![]() The block was decked .008" so this scare would go away. Because I was unsure of how deep that scare was, I had the custom pistons built with .004" less deck then a stock piston is. Once the pistons were fitted to the rods, and fitted to the block, the deck was again checked, and the block was machined a further .005" to set the squish gap @ .035" (~.9mm) - gasket + deck = .035" The engine assembly went quite smoothly...... ![]() Just need to add the timing cover, and the cam cover, and then get this on a pallet back to its owner!! More to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,553 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,908 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,362 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,159 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,716 |
