OST-044: What the "F"?
07-11-2017, 01:18 AM
intake side just about finished......
[Image: AEU86 AE86 - OST-044: What the "F"?]
more to come..... Hurray!
Dan -
07-11-2017, 12:45 PM
Stunning work as always Hurray!
Daily Beater: Civic EG5
Work in progress Car: AE86
11-15-2017, 06:13 PM
from another forum Wrote:I'm guessing there will be a custom intake manifold for this? Or is the customer going to run with the stock one?
I was trying to convince him to run something custom(similar to a stock SR20DE intake), but for now he is retaining the OEM intake.
Valve Springs Wrote:I really wish all my clients were as diligent as this one - My client is one who has done his research.....
He found a near perfect fit Wink - http://www.catcams.com/products/valvespr...CT_id=6851
The bottom end showing the MRP rods.
A point - these rods did need a bit of work to be used. The big end of the rod had some taper (.001"), and the IDs were inconsistent - varied by .0008".... but they are still far less costly then getting them from Carrillo. While there was some issues to be addressed, these issues were caught, and CORRECTED by a professional race shop!
Finally, I've been finishing the head, getting the "new" intake cam to fit, and getting the "new" exhaust valves to fit the best of the exhaust cams I have. Some were done with shims, while others had the valve "tipped" a few ten thousandths.
Dan -
11-27-2017, 08:03 PM
from another forum Wrote:The MRP rods are also slightly longer than the standard 7A rod aren't they?
about 0.5mm from memory.
To be honest... I can't confirm, or deny that...
Here is what I know........... the deck of the block was slightly damaged, requiring machining to make sure the metal gasket sealed.
The block was decked .008" so this scare would go away. Because I was unsure of how deep that scare was, I had the custom pistons built with .004" less deck then a stock piston is. Once the pistons were fitted to the rods, and fitted to the block, the deck was again checked, and the block was machined a further .005" to set the squish gap @ .035" (~.9mm) - gasket + deck = .035"
The engine assembly went quite smoothly......
Just need to add the timing cover, and the cam cover, and then get this on a pallet back to its owner!!
More to come...... Hurray!
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,423 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,535 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,171 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,033 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,616 06-28-2022 09:17 PM
