OST-048: Спасибо товарищ Сталин
04-06-2018, 05:48 PM
As to the title....
![]() ![]() ![]() ![]() While I've seen a few poor smallport castings.... this one is a pretty good casting, with decent chambers, and pretty good port-bowl alignment. What it doesn't have is a good short radius..... on ALL of the bowls.... ![]() ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-06-2018, 07:37 PM
AE86 ex-daily |
04-07-2018, 01:32 AM
(04-06-2018 07:37 PM)Bean Wrote:(04-06-2018 05:48 PM)oldeskewltoy Wrote: As to the title.... from another forum Wrote:I'll bite WTF does thanking Stalin for your happy childhood have to do with this? Try to avoid sniffing solvent my friend :omg: ![]() In one of the email correspondences with this client..... "On my Cyrillic Russian keyboard when I typed "Спасибо товарищ" [thank you comrade] the next word suggestion that came up was "Сталин" [Stalin] ? looks like my phone is a cold war veteran & a good party member!" more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-10-2018, 05:50 PM
oldeskewltoy Wrote:working the short radius, and the port walls.... ![]() and further progress.... ![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-11-2018, 05:54 PM
Been a bit of a busy beaver......
Ports are almost done - ITB adapter AND this heads new Cat cams should arrive later this week ![]() Intake bowls/seats are set, and the chambers deshrouded ![]() and I've begun the exhaust side ![]() and a bit closer (more detailed) view..... ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-12-2018, 06:57 PM
from another forum Wrote:The before & after of the exhaust ports is especially noticeable! ![]() 2 down...., 2 to go.... then it goes off to get it's 3 angle...... ![]() more to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-16-2018, 10:47 PM
![]() .... and now to get her 3 angle..... more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-21-2018, 07:03 PM
now that the 3 angle is done, its time for checking chamber volumes........
![]() all @ 37cc, so back to the shop for surfacing.... and then assembly with the new 252(222@ .050"), w/ 8.5mm lift ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-25-2018, 04:09 PM
So this engine will be using a set of ITBs. It will be using a T3 adapter.
The ITB adapter needs a bit of blending..... ![]() As do the intake ports... they too need some gentle blending ![]() I pick up the head later today, so more to come....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-02-2018, 05:16 PM
Assembly.... This client is using a Supertech spring/retainer kit.
![]() I've not been a fan of the Supertech kit. One reason is because I've not been a fan of the Supertech spring seat.... Kind of a shame actually... as there are many springs out there that can fit the stock spring seat. ![]() The Supertech spring seat is a flat steel "washer". There is nothing on the Supertech spring seat to help keep the spring located/stable in the spring pocket. Introduce the "Macer" spring seat. ![]() Richard Macer builds many racing 4AGE heads, and he has found the standard Supertech spring seat to be "wanting", so he designed and had manufactured an improved spring seat ![]() The Macer seat fits the spring pocket, and the inside "neck" helps keep the spring located, and stable. If you want to get a set, send me a note, and I'll forward contact info. Quote:I've not been a fan of the Supertech kit. One reason.... the other reason.... HELP! Supertech Retainer / stock buckets ![]() I checked valve protrusion through the retainer, I have .025" on the exhaust side, and .030"+ on the intake side... so that concern is no longer a concern..... ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,426 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,536 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,171 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,034 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,616 |
