OST-050 - a VERY special build
07-05-2018, 08:42 PM
(This post was last modified: 07-05-2018 09:19 PM by oldeskewltoy.)
more to come..... Some additional photos to later be used as reference for re-assembly. more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-05-2018, 10:07 PM
Care to share the plan for this beauty?
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
07-06-2018, 07:43 PM
(This post was last modified: 07-07-2018 02:49 AM by oldeskewltoy.)
(07-05-2018 10:07 PM)Bean Wrote: Care to share the plan for this beauty? Well... a few things to point out.... a few of the pics showed Japanese text, and for those who were looking carefully they also saw no EGR, and they saw a MAP based EFI. So this engine is JDM. But not just any JDM engine, this one is rather rare as this one was came from, and will be going back in.......... a Black Limited......... (photo below edited) 400 cars were produced. This rebuild... with a few tricks, will be going back into the Black Limited it came from. More to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-06-2018, 08:46 PM
That's a sweet Black Limited and it definitely deserves a rebuild after 31 years!
07-07-2018, 02:45 AM
(07-06-2018 08:46 PM)banpei Wrote: That's a sweet Black Limited and it definitely deserves a rebuild after 31 years! oh well.... knew I should have labelled photo "stock image"..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-09-2018, 02:06 PM
Most EU 4age are also map based
Except Switzerland,Germany?,... |
07-09-2018, 03:11 PM
(07-09-2018 02:06 PM)ditn Wrote: Most EU 4age are also map basedSwitzerland and Sweden had MAF only for sure, in Germany I think the early ones were MAP and only later due to emissions law they got the MAF version Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
07-10-2018, 02:06 AM
dismantling begins........
Each and ever piece coming off the engine gets tagged and bagged........ (some new parts also in frame) With the head off the block, it now goes out to get cleaned and checked, one thing is certain... this engine has 9.4:1 pistons. There is something else certain in this view.... ??? bearing numbers noted... can you see which crank it has?? .... and the head disassembled, nice looking cams.... especially considering this...... now no more (except deburring the rest of the head) more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-11-2018, 12:47 PM
(This post was last modified: 07-11-2018 12:48 PM by banpei.)
(07-09-2018 03:11 PM)Bean Wrote:I'm not really sure about the Germany receiving both the MAF and MAP 4A-GE, but they did indeed get two versions: one leaded (gobbling up Super Benzin) and one unleaded variant with a catalytic converter:(07-09-2018 02:06 PM)ditn Wrote: Most EU 4age are also map basedSwitzerland and Sweden had MAF only for sure, in Germany I think the early ones were MAP and only later due to emissions law they got the MAF version In Japan they also put the catalytic converter on their ordinary unleaded 4A-GE's and still put a MAP sensor on top of that. TBH: I think the leaded variant was perfectly capable of running unleaded. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
07-11-2018, 04:52 PM
(This post was last modified: 07-11-2018 06:47 PM by oldeskewltoy.)
(07-11-2018 12:47 PM)banpei Wrote: but they did indeed get two versions: one leaded (gobbling up Super Benzin) and one unleaded variant with a catalytic converter: Hmmmm, making an assumption...... I wonder......... the unleaded one - 9.4:1, the leaded one 10.0:1??? 3rd column, 2nd line down kw/ps 124ps vs 116ps... that would very likely be 10:1 vs 9.4:1 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,302 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,245 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,011 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,922 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,522 |
