OST-054: 3 rib with snap
02-06-2019, 05:35 PM
Chambers down to 35cc, ready for re-assembly. Cams are Cat cams 252/222 8.5mm lift.
[Image: AEU86 AE86 - OST-054: 3 rib with snap]
more to come..... Hurray!
Dan -
02-10-2019, 10:31 PM
14 of the 16 valves came in too tight for my shim bank (.001" variance from .110"-.125"), so I brought them back to the machine shop to get tipped (shortened) so they would be in my shim banks shim range.
As you can see the valves got tipped by different amounts, from as little as .003", to a "big" .012".
Final assembly will have all the intake valves with a clearance of .008"(0.203mm), and all the exhausts clearances at .009"(0.228mm).
Dan -
02-13-2019, 06:07 PM
from another forum Wrote:As many heads that you rebuild, take 25 minutes and make a holding fixture from small section of angle iron, that will bolt on to your bench grinder. As long as you set the valve stem square to a fine grit wheel, you can easily remove a couple thou by hand at a time. Just have a container of water handy for cooling the valve stem be measurement checks. Sure is better, then waiting on a machine shop, so you can finish the head assembly. davew
If tipping was the only thing I needed, something along those lines would work... but I've been thinking it might be time for my next equipment upgrade. My last significant change was switching from Dremels (yes plural - I used up about 6) to the Foredom 1/6hp SP hanging motor, and hand tools.
I been thinking it might be time for my own valve grinding machine.
This would allow me to do some experiments on valve back cut angles, along with precisely tipping the valves. Now, a new kwik way will run me about $7000. I might find a good used one for about $4000-$5000. The keys are the stones, and the chuck - the chuck needs to be accurate to .0005" Huh
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,423 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,535 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,170 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,033 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,616 06-28-2022 09:17 PM
