OST-054: 3 rib with snap
02-06-2019, 05:35 PM
Chambers down to 35cc, ready for re-assembly. Cams are Cat cams 252/222 8.5mm lift.
![]() more to come.....
02-10-2019, 10:31 PM
14 of the 16 valves came in too tight for my shim bank (.001" variance from .110"-.125"), so I brought them back to the machine shop to get tipped (shortened) so they would be in my shim banks shim range.
![]() As you can see the valves got tipped by different amounts, from as little as .003", to a "big" .012". Final assembly will have all the intake valves with a clearance of .008"(0.203mm), and all the exhausts clearances at .009"(0.228mm). Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-13-2019, 06:07 PM
from another forum Wrote:As many heads that you rebuild, take 25 minutes and make a holding fixture from small section of angle iron, that will bolt on to your bench grinder. As long as you set the valve stem square to a fine grit wheel, you can easily remove a couple thou by hand at a time. Just have a container of water handy for cooling the valve stem be measurement checks. Sure is better, then waiting on a machine shop, so you can finish the head assembly. davew If tipping was the only thing I needed, something along those lines would work... but I've been thinking it might be time for my next equipment upgrade. My last significant change was switching from Dremels (yes plural - I used up about 6) to the Foredom 1/6hp SP hanging motor, and hand tools. I been thinking it might be time for my own valve grinding machine. ![]() This would allow me to do some experiments on valve back cut angles, along with precisely tipping the valves. Now, a new kwik way will run me about $7000. I might find a good used one for about $4000-$5000. The keys are the stones, and the chuck - the chuck needs to be accurate to .0005" Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,718 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 9,801 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,558 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 4,425 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,516 |
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/ready_for_re-assembly.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/valves_tipped.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ep.yimg.com/ay/yhst-58082516732612/svsii-deluxe-valve-refacer-3.gif)
