OST-064: Breathing on a 3 rib
02-01-2020, 02:02 AM
[Image: AEU86 AE86 - OST-064: Breathing on a 3 rib]
more to come..... Big Grin
Dan -
02-03-2020, 06:45 PM
OST-064 "Cleaned"....
After getting it cleaned, I deburred the casting
And then before porting, I had it "tumbled" so the head now looks new, no discoloration do to oils, carbon, or coolants.
more to come...... Hurray!
Dan -
02-04-2020, 09:30 PM
Indeed it looks very clean! How many Ks did it run? Dumb question
02-06-2020, 10:57 PM
(02-04-2020 09:30 PM)banpei Wrote:  Indeed it looks very clean! How many Ks did it run? Dumb question
Ks??? Kilometers? no idea, although I do know this head has been in storage for at least 10 years before got it......
Work begins.... One done...
and a bit closer...
more to come.... Hurray!
Dan -
02-06-2020, 11:26 PM
Indeed Ks in kilometers. I know: I should have said Ms... Wink
02-11-2020, 05:37 PM (This post was last modified: 02-11-2020 05:40 PM by oldeskewltoy.)
oldeskewltoy Wrote:[Image: AEU86 AE86 - OST-064: Breathing on a 3 rib]
more to come.... Big Grin
2 down....
more to come......... Hurray!
Dan -
02-12-2020, 05:53 PM (This post was last modified: 02-12-2020 05:53 PM by oldeskewltoy.)
from another forum Wrote:what does "tumbling" the head consist of? Is it similar to tumbling bullet casings?
Not sure (tumbling bullet casings...???) What "tumbling" means in this case is they have a large tool - it consists of a large cabinet, with a rotisserie that you strap the head too. The cabinet is closet, and it tumbles inside the cabinet. The media used is cast zinc shot.
a bit further yesterday..... 3 down....
and an up close view inside on the exhaust side....
more to come..... Hurray!
Dan -
02-15-2020, 04:42 AM
4 down....
Dan -
03-12-2020, 12:09 AM
and the internals.......
crank on right has wankered key groove in snout
Dan -
03-19-2020, 02:30 AM
everything is back in my hands for final assembly....
head, with fresh valve job (machined .008")...
along with assembled short block - those are Molnar Tech 40/20 H- beam rods
Does anyone see the remnants of a problem in the deck???
It took a great deal of decking to get the block suitable to accept a metal gasket.... so much so that our deck is now .018" (piston above the deck!)
The "fix", Cometic C4166-051, that should set the squish back to .033", or just a tick above .8mm.......
More to come..... Hurray!
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,369 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,395 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,087 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 1,981 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,562 06-28-2022 09:17 PM
