OST-069: Transformation
11-05-2020, 06:32 PM
(This post was last modified: 11-05-2020 06:35 PM by oldeskewltoy.)
OST-069 begins its transformation with a cleaning..... Nasty..... top and bottom.... and while a cleaning gets it suitable for work.... it is still too nasty to sell... so add another step... tumble it!! more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-05-2020, 06:56 PM
Nice work
Sent from my ANE-LX1 using Tapatalk |
11-07-2020, 10:34 PM
(This post was last modified: 11-07-2020 10:35 PM by banpei.)
Nice cleaning!
Maybe I have missed this, but you have a big tumble cleaner that are large enough to fit engine heads? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-12-2020, 11:04 PM
(11-07-2020 10:34 PM)banpei Wrote: Maybe I have missed this, but you have a big tumble cleaner that are large enough to fit engine heads? No, one of the machine shops I use has a large "tumbler" - large enough for blocks! The tumbler is partially filled with zinc shot. They close the lid and the head is dragged repeatedly though the zinc shot. Porting begins.... #1 on the right, had a bit of a step left after the factory machining, I cut this back and smoothed it out. On the left, #2, adjusting the seat and bowl I frequently have to "fix" core shift, here is a prime example from the exhaust side 2 down... 2 to go.... more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-13-2020, 10:48 PM
(11-12-2020 11:04 PM)oldeskewltoy Wrote:Nice!(11-07-2020 10:34 PM)banpei Wrote: Maybe I have missed this, but you have a big tumble cleaner that are large enough to fit engine heads? I was always wondering how you get those heads look like new but now we know your secret. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-14-2020, 10:50 AM
Vapour blasting makes for an even nicer looking result.. not too common though.
The tumbler probably gets to hard to reach inside cavities better, but that is as much of a risk as a benefit. FABRICA MI DIEM, PVNC! |
11-15-2020, 11:07 PM
I have seen people smooth the valve guides down so they are flush with the IN/EX channel, is there any reason for doing this, or is it overdoing it.?
Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
11-24-2020, 08:31 PM
(11-15-2020 11:07 PM)Vaptor Wrote: I have seen people smooth the valve guides down so they are flush with the IN/EX channel, is there any reason for doing this, or is it overdoing it.? good question.... I assume you mean something similar to this..... the actual 4AGE/ZE valve guide is all of 1.6" long....it holds the 4AG valve stable at valve speeds up to 75 opening/closings per second...... The more you shorten it, the less stable the valve becomes. Shorten it a little, and it isn't likely to be an issue, shorten it more....??? But how short is too short?? I can't tell you..... for I don't know. What I do know, is Loynings does use guides on many of their 4AG race engines, while removing the guide boss, they still keep the guides.... In the same breath... I have shortened guides in one of my head builds... but it wasn't a 4AG... and it wasn't shortening them as much as in the above photo. I was building a 1GG head, and the guides were longer then the 4AG guides, with similar, or less lift then a 4AG..... so I shortened them intake.... exhaust.... When I port heads I've tried to follow one underlying rule..... "do no harm" Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-25-2020, 09:49 PM
(This post was last modified: 11-25-2020 09:50 PM by Vaptor.)
Thank you Dan for this deep explanation to my question
First picture was exactly what I was referring to. With standard Guides length, it can keep the valve stable to a max of 75 opening/closing per sec, so for High RPM with High lift, better keep the Guides to a standard length and not experiment to much, although the Lorring approach looks interesting Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
11-27-2020, 05:26 PM
(This post was last modified: 11-27-2020 05:27 PM by oldeskewltoy.)
(11-25-2020 09:49 PM)Vaptor Wrote: Thank you Dan for this deep explanation to my question be careful about using absolutes - some 4AG engines (Loynings, or Hasselgren) make then to spin upwards of 92 valve oscillation (openings/closings) per second Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,336 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,341 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,037 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,943 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,534 |
