OST-069: Transformation
11-05-2020, 06:32 PM (This post was last modified: 11-05-2020 06:35 PM by oldeskewltoy.)
[Image: AEU86 AE86 - OST-069: Transformation]
OST-069 begins its transformation with a cleaning.....
Nasty..... top
and bottom....
and while a cleaning gets it suitable for work....
it is still too nasty to sell... so add another step... tumble it!!
more to come.... Hurray!
Dan -
11-05-2020, 06:56 PM
Nice work
Sent from my ANE-LX1 using Tapatalk
11-07-2020, 10:34 PM (This post was last modified: 11-07-2020 10:35 PM by banpei.)
Nice cleaning! Thumbs up!
Maybe I have missed this, but you have a big tumble cleaner that are large enough to fit engine heads? Dumb question
11-12-2020, 11:04 PM
(11-07-2020 10:34 PM)banpei Wrote:  Maybe I have missed this, but you have a big tumble cleaner that are large enough to fit engine heads? Dumb question
No, one of the machine shops I use has a large "tumbler" - large enough for blocks! The tumbler is partially filled with zinc shot. They close the lid and the head is dragged repeatedly though the zinc shot.
Porting begins.... #1 on the right, had a bit of a step left after the factory machining, I cut this back and smoothed it out. On the left, #2, adjusting the seat and bowl
I frequently have to "fix" core shift, here is a prime example from the exhaust side
2 down... 2 to go....
more to come...... Hurray!
Dan -
11-13-2020, 10:48 PM
Nice! Thumbs up!
I was always wondering how you get those heads look like new but now we know your secret. Dodgy
11-14-2020, 10:50 AM
Vapour blasting makes for an even nicer looking result.. not too common though.
The tumbler probably gets to hard to reach inside cavities better, but that is as much of a risk as a benefit.
11-15-2020, 11:07 PM
Photo OST-069: Transformation
I have seen people smooth the valve guides down so they are flush with the IN/EX channel, is there any reason for doing this, or is it overdoing it.?
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
11-24-2020, 08:31 PM
(11-15-2020 11:07 PM)Vaptor Wrote:  I have seen people smooth the valve guides down so they are flush with the IN/EX channel, is there any reason for doing this, or is it overdoing it.?
good question....
I assume you mean something similar to this.....
the actual 4AGE/ZE valve guide is all of 1.6" long....it holds the 4AG valve stable at valve speeds up to 75 opening/closings per second......
The more you shorten it, the less stable the valve becomes. Shorten it a little, and it isn't likely to be an issue, shorten it more....???
But how short is too short?? I can't tell you..... for I don't know.
What I do know, is Loynings does use guides on many of their 4AG race engines, while removing the guide boss, they still keep the guides....
In the same breath... I have shortened guides in one of my head builds... but it wasn't a 4AG... and it wasn't shortening them as much as in the above photo.
I was building a 1GG head, and the guides were longer then the 4AG guides, with similar, or less lift then a 4AG..... so I shortened them
intake....
exhaust....
When I port heads I've tried to follow one underlying rule..... "do no harm" Wink
Dan -
11-25-2020, 09:49 PM (This post was last modified: 11-25-2020 09:50 PM by Vaptor.)
Thank you Dan for this deep explanation to my question Smile
First picture was exactly what I was referring to.
With standard Guides length, it can keep the valve stable to a max of 75 opening/closing per sec, so for High RPM with High lift, better keep the Guides to a standard length and not experiment to much, although the Lorring approach looks interesting Love it!
11-27-2020, 05:26 PM (This post was last modified: 11-27-2020 05:27 PM by oldeskewltoy.)
(11-25-2020 09:49 PM)Vaptor Wrote:  Thank you Dan for this deep explanation to my question Smile
be careful about using absolutes - some 4AG engines (Loynings, or Hasselgren) make then to spin upwards of 92 valve oscillation (openings/closings) per second
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,575 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,991 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,382 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,175 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,723 06-28-2022 09:17 PM
