OST-075: Blue(top) Hawaii
05-04-2021, 05:36 PM
![]() After discussing this build with my client, he sent me his largeport head, and his Crower cams. ![]() Unpacked... ![]() cam covers removed.... ![]() and fully disassembled, prior to getting cleaned, pressure checked, and tumbled ![]() more to come.......
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-05-2021, 10:11 PM
(This post was last modified: 05-05-2021 10:12 PM by oldeskewltoy.)
A closer look at the valves......
Once you get past the really bad one... do you see it? ![]() The TVIS effect.... Valves 1, 4,5, and 8, the valves w/o the TVIS butterflies have far more build up. ![]() ... and this head has been serviced at least once before... head machined... ... and valve job?? ![]() more to come.....
05-05-2021, 10:45 PM
Are those valve seats machined crookedly?
05-06-2021, 07:05 PM
(05-05-2021 10:45 PM)Ivan141 Wrote: Are those valve seats machined crookedly? Why yes.... yes they are . And don't ask how they did it... cause I don't even know..... This is just another reason to get the head properly rebuilt.... So, on to deburring the head, and I found this ![]() simply amazing...................... Now, this is the cam card that came with my client's cams..... ![]() anyone tell me what seems to be wrong??? More to come......
05-06-2021, 10:51 PM
(This post was last modified: 05-07-2021 09:09 AM by Bean.)
The nomenclature is very strange to begin with and the visual aid isn't helping at all with the intake going full circle.
The duration @0.05 lift and the opening closing degrees don't add up for me. The intake calcutes to 212 but the exhaust ends up at 228. If I interpret the minus sign for the exhaust wrong I can get it to 212 but then there wouldn't be any overlap (on the contrary all valves would be closed for 8°). Also the ramp seems to be very slow/wide but that might just be me as I'm comparing it to Catcams which are known for a rather aggressive ramp angle. I haven't wrapped my brain around engine related things for years and it's very late so I might be completely off AE86 ex-daily |
05-10-2021, 06:26 PM
(This post was last modified: 05-10-2021 06:31 PM by oldeskewltoy.)
(05-06-2021 10:51 PM)Bean Wrote: The nomenclature is very strange to begin with and the visual aid isn't helping at all with the intake going full circle. from another forum Wrote:I'll venture an uneducated guess. A negative number for the exhaust valve closure, i.e. -8.0 BTDC. Perhaps a negative "before" degree reading equals "after"? In this case it is 8 degrees BTDC, otherwise as Bean mentioned we would be @ 228 if it were after TDC. A few things to remember most of the mild cams will close the exhaust valve BTDC, or close to TDC, while still at a certain lift point (either .040"/1mm, or .050"), seat to seat the valve still usually closes after top dead center - dependent on cam timing. agreed, their timing wheel/diagram doesn't help either...... As to comparing them to Cat cams - yes, the Crower are far more mild a ramp, and offer only a minimal lift increase (7.75mm lift) over stock cams. The Cat cams I typically recommend for mild builds are 212 @ .040" (likely around [email protected]"), but with 8mm lift. So the Cat cams are a tiny bit shorter in duration @, much shorter in duration overall, and offer more lift. The Crowers will twist a few hundred more rpm. But while all that is pertinent, that wasn't what I was after..... This is what I was focused on..... Crower had HOT clearances... something you just don't get, and the FSM only has a reference for.... AND the reference is looser then Crower's spec - possibly making clearances too tight on the Crower cams.... ![]() ![]() more to come....... ![]() PS - didn't keep the weight....
05-11-2021, 10:13 AM
I seen the clearance thing but disregarded the 'hot' part entirely as the seemed in the ballpark for 'cold' - maybe another typo?
Have you tried contacting Crower - as there's some blurb about changed specs and stuff? AE86 ex-daily |
05-13-2021, 10:10 PM
(05-11-2021 10:13 AM)Bean Wrote: I seen the clearance thing but disregarded the 'hot' part entirely as the seemed in the ballpark for 'cold' - maybe another typo? I called, and left a message, as well as emailing them. No answer..... Then I got the brilliant idea of doing a search on their website.... bingo. Some changes - clearances no longer specified hot, some absent info - TRD single springs are no longer available, so no spring listed. Timing wheel better... but still inaccurate, or at least it doesn't represent actual timing. ![]() now 2 down..... ![]() from a slightly different perspective ![]() more to come.....
05-13-2021, 10:52 PM
(This post was last modified: 05-13-2021 10:55 PM by Bean.)
I know it's tedious but in my opinion you would be best off to measure it yourself - if they did change the specs at one point who knows what version you have in hand.
EDIT: as for the illustration it looks intended as an abstract and not to the actual degree as 8° ATDC isn't anywhere close to what is pictured in either of the two drawings AE86 ex-daily |
05-22-2021, 01:36 AM
(05-13-2021 10:52 PM)Bean Wrote: I know it's tedious but in my opinion you would be best off to measure it yourself - if they did change the specs at one point who knows what version you have in hand. Agreed, I set clearances to .006" on the intake side, and .008" on the exhaust side. As far as cam timing, that is in my client's hands - I did send him both cam cards - so he should be able to set them up. From 3 down to 4 down....... ![]() And off to the machine shop where that horrible valve job went away.... ![]() Once back in my hands, a quick re-assembly... and checking clearances.... ![]() A big swing is needed... 10 of 16 valves I can't get a clearance on.... so back to the shop to get them tipped - If you look to the far left you can see how much I had the intake valves tipped.... Now with clearances set - a set of faux cams is fitted to keep the shims/buckets in place during return shipping.
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,683 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,434 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,039 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,287 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,665 |
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/normal_ost-075.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/Arrived.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/before_disassembly_with_cam_covers.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/before_disassembly~1.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/diassembled.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/valves_upon_removal.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/normal_thickness_115_88.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/normal_bad_valve_job_-_previous.jpg)
. And don't ask how they did it... cause I don't even know..... ![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/normal_deburring_found_extra_material.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/cam_card_-_Crower_61821-2__268_degree.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](http://www.mr2.com/forums/images/smilies/wtf.gif)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/cam_card_-_Crower_61821-2__268_degree_with_FSM_minimum_valve_clearance_hot_circled.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/Cam_card_2021_complete~0.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/1_down_to_2_down_from_chamber_view_2_panel.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/1_down_to_2_down_from_exhaust_view_2_panel.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/3_down_4_down_2_panel.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/bad_valve_job_good_valve_job_annoted_2panel.jpg)
![AEU86 AE86 - OST-075: Blue(top) Hawaii [Image: AEU86 AE86 - OST-075: Blue(top) Hawaii]](https://gallery.ostportworks.com/albums/userpics/10005/quiz_3B29.jpg)
