Oil Presure and what oil i have to use?
08-21-2008, 02:47 AM
Hello i have a engine 4AGZE with a turbine T3/T4
i have two question
1 - the oil psi in stock idle?
2 - the best oil for the 4AGZE ?
08-21-2008, 09:59 AM
check this for a summary of used oils in the 4AGE/4AGZE (and well, the complete driveline Tongue).
http://www.aeu86.org/viewtopic/ae86/p/95842#95842
opinions about best oils are plenty, but most agree: just use the oil grade that is stated in your booklet. Just about any 10W40 oil will do for the engine, whatever you prefer.
[Image: AEU86 AE86 - Oil Presure and what oil i have to use?]
08-21-2008, 04:37 PM
oil pressure at idle can often be much lower than in load conditions.. I dont know if that's a usefull thing to know. Did seem to be higher in most 4age's that I've seen than in my moms miata.
08-27-2008, 05:35 AM
I usually use 10-30w for new engines and 20-50w for older engines.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  How would/have you rebuild your 4age? joaotcgt 6 9,000 07-21-2015 10:40 AM
  How far should I have to push my clutch in dinkers542 4 6,209 11-29-2014 11:18 PM
Last Post: dinkers542
  trans oil, lsd oil change Apolan 9 17,168 10-01-2014 03:57 PM
  Quick question for those who have relocated their battery.. Jezza_hr 10 11,029 03-06-2014 12:38 AM
Last Post: rene
  Oil cooler -> low oil pressure Jan Pedersen 24 30,769 06-06-2013 07:36 PM
Last Post: Deuce Cam
