Oil Presure and what oil i have to use?
08-21-2008, 02:47 AM
Hello i have a engine 4AGZE with a turbine T3/T4
i have two question 1 - the oil psi in stock idle? 2 - the best oil for the 4AGZE ? |
08-21-2008, 09:59 AM
check this for a summary of used oils in the 4AGE/4AGZE (and well, the complete driveline ).
http://www.aeu86.org/viewtopic/ae86/p/95842#95842 opinions about best oils are plenty, but most agree: just use the oil grade that is stated in your booklet. Just about any 10W40 oil will do for the engine, whatever you prefer. |
08-21-2008, 04:37 PM
oil pressure at idle can often be much lower than in load conditions.. I dont know if that's a usefull thing to know. Did seem to be higher in most 4age's that I've seen than in my moms miata.
08-27-2008, 05:35 AM
I usually use 10-30w for new engines and 20-50w for older engines.
How would/have you rebuild your 4age? | joaotcgt | 6 | 9,083 |
07-21-2015 10:40 AM Last Post: mad.matt |
How far should I have to push my clutch in | dinkers542 | 4 | 6,242 |
11-29-2014 11:18 PM Last Post: dinkers542 |
trans oil, lsd oil change | Apolan | 9 | 17,244 |
Quick question for those who have relocated their battery.. | Jezza_hr | 10 | 11,106 |
03-06-2014 12:38 AM Last Post: rene |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,940 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
