Oil pressure sensor / gauge
05-10-2005, 07:59 AM
Hi,
A little question which might be tricky.... the 4AGE has an oil pressure sensor that has 1 connection, and I guess it gives a certain resistance to ground which changes with oil pressure, and my question is, what is the value (range) of this sensor? I ask becaus I have an aftermarket oil pressure gauge (Racimex) with a sensor with 2 connections, but I dont want to leave the oem gauge 'out of order' so I'm looking for a way to wire it up too on the Racimex sensor I tried yesterday, one of the connections it gave me 100% of the pressure and on the other one 0% ..... thanks Patrick |
05-10-2005, 11:53 AM
1 for pressure and the other is probably for a warninglight.
Broken down 1984 Trueno HB ![]() |
EUDM gauge cluster | banpei | 22 | 5,654 |
08-15-2023 10:48 PM Last Post: banpei |
Lambda sensor wiring | sam3007 | 10 | 4,995 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,827 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 8,085 |
12-06-2017 06:48 PM Last Post: Bean |
Analog gauge cluster tech | Ivan141 | 33 | 44,228 |
01-31-2016 11:06 PM Last Post: Bean |
