Vibration/Shudder In steering over approx 100kph
05-10-2005, 08:50 AM
Hi guys,
I wonder if you can confirm a problem I have from my poor description. I am getting some shaking in the steering on my hachi over 100kph. Its been there since I got the car.
I've pretty much ruled out a bent half shaft, my wheels have all been balanced and the wheel bearings all seem good.
I am guessing its going to be one of the balljoints on the end of the track control arms. Has anyone else experienced this ?
Regards Ian.
[Image: AEU86 AE86 - Vibration/Shudder In steeri...rox 100kph]
05-10-2005, 08:56 AM
Ian.G Wrote:Hi guys,
Hmmm, the balljoints of my mitsu should be replaced pretty soon and I don't get shaking in the steering. It's more a bit like the car steers by itself. If I turn the wheel it feels like it takes half a second before anything happens. This only happens when I drive faster than 100kph. When I drive below that the car reacts normal. Undecided
05-10-2005, 09:25 AM
I have the same problem. Wheels were balanced 2 weeks ago and everything else seems to be in order... Maybe we just have to live with it (its a 20 year old car after all...)
05-10-2005, 09:48 AM
I have no such problem. Wheels were balanced once when the (used) tires fitted, and never had problems. Whenever i had such problem it was unbalanced wheel.
Try to make an "on car" wheel balance.
http://www.ae86.gr
05-10-2005, 10:50 AM
I think guys that the problem is not very well centered rims to the car...(sorry for my poor english here Sad )
if the rims are changed you 'll have to get some o-rings for the new ones for an accurate positioning of them on the car.
Same problems i got here and solve it by custom made teflon-rings (50euros if i remember well)
Hope i helped... Thumbs up!
05-10-2005, 11:02 AM
Hmmm...
I am running 5mm spacers on the front - I wonder if they are not faced onto the mounting surface or the brakedisk/hub correctly ???
Maybe I'll clean them up and see what happens.
Regards Ian.
05-10-2005, 11:13 AM
"I wonder if they are not faced onto the mounting surface or the brakedisk/hub correctly ???
Maybe I'll clean them up and see what happens"
That's right Ian!
And look if they are exactly centered there... :wink:
05-10-2005, 02:20 PM
You may check also rubber gear mount and the lager in the middle of driveshaft (the driveshaft is 2-piece item).
  Over heating issues MIGGZFSU 12 12,448 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,840 11-29-2014 12:27 AM
Last Post: dinkers542
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 45,217 10-02-2014 06:07 PM
  Start wont turn over after installing radio MC_JP 6 10,135 09-22-2014 11:13 PM
Last Post: izanagi
  driveline vibration TE71 teun 23 24,081 03-07-2014 10:36 PM
Last Post: totta Crolla
User(s) browsing this thread:
