Over heating issues
05-08-2017, 10:35 PM
Over heating issues
Hey guys
OK so the first drive I took with this car the radiator exploded
Then got the radiator repaired and installed
Cleaned out the pipes and noticed no thermostat so left it out
It's got the stock fan but no cowling
If the car idles no issue but when I drive for more then 4km it get hot and really hot.
I flushed the system, looks like the waterpump is flowing can see the water movement in the radiator and both pipes from rad are warm and stiff
What's the thoughts
Sent from my F3111 using Tapatalk
Signature removed due to large photobucket message
05-08-2017, 11:09 PM
Over heating issues
put a thermostat in would be my first point of call.
05-09-2017, 07:45 AM
Over heating issues
Considering the car is overheating already the thermostat won't help... got to be something else...
Sent from my SM-T800 using Tapatalk
05-09-2017, 10:15 AM
Over heating issues
Do you have a proper radiator cap that pressurizes the system? Or is there an open connection to the overflow bottle?
Also did you properly de-air the system after refilling?
AE86 Levin
05-09-2017, 12:33 PM
Over heating issues
How stiff are the water tubes? Sounds like a possible headgasket / cracked head block issue.
There's a reason someone took out the thermostat, most likely to temporarily cover up overheating
issues.
05-10-2017, 08:44 AM
Over heating issues
Hey guys will go through now what iv done to date
Water pump flowing
No water in oil or oil in water, no smoke
Bled the system correctly
Cap on radiator is functioning
Did a pressure test on the system then took the spark plugs out and cranked the car no water coming out there
So I have ordered a thermostat
Going to install that, if no luck I'm going to connect up the electric fan and see, if still no luck I'm parking the car off for a while
05-10-2017, 12:11 PM
Over heating issues
What kind of set-up are you running? Oem engine, oem radiator etc? Oem bumpers? (Because of airflow)
Also could it be running lean? I know this causes higher exhaust temps but not sure to what extent this has an effect on the temp during idling.
AE86 Levin
05-10-2017, 12:21 PM
Over heating issues
(05-10-2017 12:11 PM)bozu Wrote:  What kind of set-up are you running? Oem engine, oem radiator etc? Oem bumpers? (Because of airflow)
all oem stuffs bud
I actually dont know if its running lean to be honest ill have a look
05-10-2017, 12:32 PM
Over heating issues
Does your car still have the automatic transmission installed?
On my Carina I have the A40 automatic transmission that uses the radiator to cool the transmission oil as well. It could be the case that the combination of both is too much for yours.
[Image: AEU86 AE86 - Over heating issues]
05-10-2017, 12:33 PM
Over heating issues
Yeah still auto and using that combo
But everything is still stock?
and when im driving the car is at night and its like 10'c here
  Running issues sam3007 6 2,792 06-26-2022 01:34 PM
Last Post: Dave W
  Shortshifter TRD - Issues pack 13 12,654 09-19-2016 10:57 PM
Last Post: jondee86
  20v Starting Issues mad.matt 10 11,690 09-24-2014 12:44 PM
Last Post: pack
  Start wont turn over after installing radio MC_JP 6 9,675 09-22-2014 11:13 PM
Last Post: izanagi
  SR20DET (S13) gearbox shifting issues in AE86 heshan 8 11,240 07-22-2014 01:07 PM
Last Post: heshan
