Over heating issues
05-08-2017, 10:35 PM
Over heating issues
Hey guys
OK so the first drive I took with this car the radiator exploded Then got the radiator repaired and installed Cleaned out the pipes and noticed no thermostat so left it out It's got the stock fan but no cowling If the car idles no issue but when I drive for more then 4km it get hot and really hot. I flushed the system, looks like the waterpump is flowing can see the water movement in the radiator and both pipes from rad are warm and stiff What's the thoughts Sent from my F3111 using Tapatalk |
05-08-2017, 11:09 PM
Over heating issues
put a thermostat in would be my first point of call.
05-09-2017, 07:45 AM
Over heating issues
Considering the car is overheating already the thermostat won't help... got to be something else...
Sent from my SM-T800 using Tapatalk AE86 ex-daily |
05-09-2017, 10:15 AM
Over heating issues
Do you have a proper radiator cap that pressurizes the system? Or is there an open connection to the overflow bottle?
Also did you properly de-air the system after refilling? AE86 Levin |
05-09-2017, 12:33 PM
Over heating issues
How stiff are the water tubes? Sounds like a possible headgasket / cracked head block issue.
There's a reason someone took out the thermostat, most likely to temporarily cover up overheating issues. FABRICA MI DIEM, PVNC! |
05-10-2017, 08:44 AM
Over heating issues
Hey guys will go through now what iv done to date
Water pump flowing No water in oil or oil in water, no smoke Bled the system correctly Cap on radiator is functioning Did a pressure test on the system then took the spark plugs out and cranked the car no water coming out there So I have ordered a thermostat Going to install that, if no luck I'm going to connect up the electric fan and see, if still no luck I'm parking the car off for a while Sent from my F3111 using Tapatalk |
05-10-2017, 12:11 PM
Over heating issues
What kind of set-up are you running? Oem engine, oem radiator etc? Oem bumpers? (Because of airflow)
Also could it be running lean? I know this causes higher exhaust temps but not sure to what extent this has an effect on the temp during idling. AE86 Levin |
05-10-2017, 12:21 PM
Over heating issues
(05-10-2017 12:11 PM)bozu Wrote: What kind of set-up are you running? Oem engine, oem radiator etc? Oem bumpers? (Because of airflow) all oem stuffs bud I actually dont know if its running lean to be honest ill have a look |
05-10-2017, 12:32 PM
Over heating issues
Does your car still have the automatic transmission installed?
On my Carina I have the A40 automatic transmission that uses the radiator to cool the transmission oil as well. It could be the case that the combination of both is too much for yours. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
05-10-2017, 12:33 PM
Over heating issues
Yeah still auto and using that combo
But everything is still stock? and when im driving the car is at night and its like 10'c here |
Running issues | sam3007 | 6 | 3,645 |
Shortshifter TRD - Issues | pack | 13 | 14,328 |
09-19-2016 10:57 PM Last Post: jondee86 |
20v Starting Issues | mad.matt | 10 | 12,910 |
09-24-2014 12:44 PM Last Post: pack |
Start wont turn over after installing radio | MC_JP | 6 | 10,606 |
09-22-2014 11:13 PM Last Post: izanagi |
SR20DET (S13) gearbox shifting issues in AE86 | heshan | 8 | 12,206 |
07-22-2014 01:07 PM Last Post: heshan |
