PROPELLER SHAFT Problems
03-29-2009, 03:12 PM
PROPELLER SHAFT my AE86 is unbalanced when I go over 80k/hy get the car started vibrating in neutral how can i resolved this buying a new PROPELLER SHAFT where i can find it ?
one more question
what type of Shaft is used by the GTS ?
for example in the ECP Part the have 2 Diferents type of Shaft
1 - PROPELLER SHAFT & UNIVERSAL JOINT 3 jOINT Type
2 - PROPELLER SHAFT & UNIVERSAL JOINT 2 JOINT Type
i put a 4AG with T-50 Trans
03-29-2009, 03:49 PM
you need the 3 joint type
http://www.toyodiy.com/parts/p_E_1984_TO..._3701.html
03-29-2009, 04:26 PM
ok, but my car is not the GTS
is a SR5 Automatic i make the swap of the engine
this can work /
  Big wheel problems gh0st 16 8,939 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,870 08-31-2021 06:20 PM
Last Post: totta Crolla
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,290 07-31-2019 11:28 AM
  Steering shaft issue Ryo 15 13,468 11-19-2018 09:52 AM
  Problems Mintex M1155 pads Dino86 9 9,390 07-04-2017 11:22 AM
User(s) browsing this thread:
