Panhard Rod Bolt Sizes
11-01-2011, 05:01 PM
Does anyone know the diameter of the threads of the bolts for the panhard rod?
Making an adjustable panhard rod but need to know the size of the bolts for the rose joints. |
11-01-2011, 05:03 PM
20mm and 12mm
11-01-2011, 05:17 PM
Project D Wrote:20mm and 12mm Awesome ![]() Cheers Dude! |
11-06-2011, 11:35 PM
And the result of my labours!
11-07-2011, 12:24 AM
most brand use 14 / 16mm rod for the small end since you will need spacers to get the same thickness as original.
Nice work anyway ! Now you can make the 4 links ![]() |
11-07-2011, 01:46 PM
Yeah I did have to use spacers.
Thanks! Would definitely like to make the 4 links. Cant believe how much cheaper it was to do this myself. Do you have bolt sizes or recommended sizes for the rose joints i will need to do the 4 links? |
11-07-2011, 04:50 PM
All bolts are 12mm (like the panhard)
Most japanese brand use 14mm rose joints. The thickness of the original bushing on the 4 links are 50mm (to make your spacers ![]() Lenght: 245mm & 470mm (+/-2mm) |
11-07-2011, 06:55 PM
Project D Wrote:All bolts are 12mm (like the panhard) Your my Hero! ![]() So much easier than having to take them off to measure and then wait for parts! So have you done this yourself before? If so what size tubing did you use? |
Question on Rod Bearings | mister86 | 3 | 4,288 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
Cam Cap Bolt Snapped!! | Alex170984 | 1 | 3,895 |
06-08-2018 01:17 PM Last Post: Ivan141 |
crank 6 bolt flywheel | DJexor | 5 | 8,376 |
12-05-2016 08:21 AM Last Post: d3nso |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,511 |
03-22-2016 09:43 PM Last Post: ditn |
4A-GE 20V ITB bolt patterns | kjb | 7 | 12,502 |
02-27-2016 01:23 PM Last Post: kjb |
