Panhard Rod Bolt Sizes
11-01-2011, 05:01 PM
Does anyone know the diameter of the threads of the bolts for the panhard rod?
Making an adjustable panhard rod but need to know the size of the bolts for the rose joints.
11-01-2011, 05:03 PM
20mm and 12mm
11-01-2011, 05:17 PM
Project D Wrote:20mm and 12mm
Awesome Thumbs up!
Cheers Dude!
11-06-2011, 11:35 PM
And the result of my labours!
[Image: AEU86 AE86 - Panhard Rod Bolt Sizes]
11-07-2011, 12:24 AM
most brand use 14 / 16mm rod for the small end since you will need spacers to get the same thickness as original.
Nice work anyway !
Now you can make the 4 links Cool
11-07-2011, 01:46 PM
Yeah I did have to use spacers.
Thanks!
Would definitely like to make the 4 links. Cant believe how much cheaper it was to do this myself.
Do you have bolt sizes or recommended sizes for the rose joints i will need to do the 4 links?
11-07-2011, 04:50 PM
All bolts are 12mm (like the panhard)
Most japanese brand use 14mm rose joints.
The thickness of the original bushing on the 4 links are 50mm (to make your spacers Wink)
Lenght: 245mm & 470mm (+/-2mm)
11-07-2011, 06:55 PM
Project D Wrote:All bolts are 12mm (like the panhard)
Your my Hero! Respect!
So much easier than having to take them off to measure and then wait for parts!
So have you done this yourself before? If so what size tubing did you use?
  Question on Rod Bearings mister86 3 4,293 03-19-2020 03:46 AM
  Cam Cap Bolt Snapped!! Alex170984 1 3,901 06-08-2018 01:17 PM
  crank 6 bolt flywheel DJexor 5 8,381 12-05-2016 08:21 AM
Last Post: d3nso
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 4,520 03-22-2016 09:43 PM
Last Post: ditn
  4A-GE 20V ITB bolt patterns kjb 7 12,514 02-27-2016 01:23 PM
Last Post: kjb
User(s) browsing this thread:
