Parts Nos ? Diff Pumpkin drain and fill plugs
08-21-2005, 10:30 AM
Hi guys do any of you have the part numbers for the above drain and filling plugs on the diff pumpkins ? also are there any seals that should be replaced with them ?
Regards Ian.
[Image: AEU86 AE86 - Parts Nos ? Diff Pumpkin dr...fill plugs]
08-21-2005, 12:01 PM
Hey Ian,
The plugs just need one of those copper rings to make them fluid tight..
Not sure about the part numbers but why not visit the local scrapyard and take them off of some axle?
12157-10010 Drain & filler plug gasket (order 2)
90341-18057 Drain Plug
90341-18049 Filler plug for 83- june 86 models
90341-18006 Filler plug for juli 86-87 models
Happy shopping!
08-21-2005, 04:18 PM
Cheers Ivan,
is there any noticable difference between the pumpkins on the Zenki and Kouki pumpkins so I can tell what I have ? - I know some axles have slightly thinner halfshalfs - I just want to replace them with new ones as one is in poor shape.
Regards Ian.
08-21-2005, 05:24 PM
I think the drain plugs are much the same on almost all ae86's..I was rather puzzled by the fact that the last years had different filler plugs.
About the halfshafts, the thickness is different, and the splines are incompatible (as are the differentials). I dont think they are interchangeable. I only know of the US guys shortening open diff halfshafts to fit lsd's, but then they still have to make sure they get the right generation of lsd.
What exactly is in poor shape on your axle? If it's just the plugs go ahead and replace them..
08-21-2005, 06:15 PM
Cheers Again,
its just the plugs Ivan, one of them has been a bit rounded off so when I eventually take it off I want to replace it.
Do you normally drop your lateral rod out of the way to make more space ?
Regards Ian.
08-21-2005, 11:45 PM
Why would you want to do that? It has never gotten in my way before..
Anyway, just check your hachi's build date as far as that is possible, and change those plugs..
  Gearbox and Diff options MIGGZFSU 35 28,845 03-26-2017 12:00 AM
Last Post: MIGGZFSU
  Core Plugs Alex170984 6 8,192 06-10-2013 07:59 PM
Last Post: The Doctor
  20v no spark & dry plugs. Rascal21 26 35,960 05-10-2013 02:47 AM
Last Post: Rascal21
  Spark Plugs on modded 16v apardal 1 3,738 03-15-2012 08:14 PM
Last Post: apardal
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,438 12-16-2011 11:14 AM
Last Post: bakonick
